Suspension & Brakes Theory, alignment, spring rates....
Koni install problem/question
Old Sep 9, 2005 | 06:36 PM
c_buz's Avatar
Default Koni install problem/question
I purchased a set of koni Race shocks for my 94 honda civic. On the instructions it says I can adjust the firmness of the shock by turning it clockwise while gripping the main shaft with a vice (before instalation of course). What is the purpose of this? Can't I adjust it the same way using the white plastic key included with the shocks? I also turned one of them (can't remember which one ) how do I reset it back to zero?
Old Sep 10, 2005 | 06:11 AM
c_buz's Avatar
Default Re: Koni install problem/question (c_buz)
bump
Old Sep 10, 2005 | 04:06 PM
krnfly2damoon's Avatar
it controls the how stiff you want your shocks to be
you can have full 2 rotations, turning right will make it stiff(less bouncier)
and turning it left will make is more bouncier
so turn it alll the way left and start turning them right, until you think it is stiff enuogh for you.
Old Sep 11, 2005 | 06:14 AM
c_buz's Avatar
Default Re: Koni install problem/question (krnfly2damoon)
but do I have to do this while they are out of the car or adjusting them with the white key achieves the same results?
Old Sep 11, 2005 | 09:13 AM
Solracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c_buz &raquo;</TD></TR><TR><TD CLASS="quote">but do I have to do this while they are out of the car or adjusting them with the white key achieves the same results?</TD></TR></TABLE>
I would like to know what instructions are telling you do this with a vise before you install the shocks, I have only ever adjusted my Koni Yellows with the adjustment **** on the top of the shock.
Which Koni's do you have? Red or Yellow?
Old Sep 11, 2005 | 09:30 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: Koni install problem/question (Solracer)
probably the 2812`s.
Old Sep 11, 2005 | 01:52 PM
c_buz's Avatar
Default Re: Koni install problem/question (vtecvoodoo)
Actually they are the 1153 and 1152 RACE. Same as sports for the eg but with re-valving.
Old Sep 12, 2005 | 06:24 AM
be.twenty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer &raquo;</TD></TR><TR><TD CLASS="quote">I would like to know what instructions are telling you do this with a vise before you install the shocks, I have only ever adjusted my Koni Yellows with the adjustment **** on the top of the shock.
Which Koni's do you have? Red or Yellow?</TD></TR></TABLE>
in the box, the instructions say to "test" them out by holding the rod with a vise and pushing and pulling the shock... also says to test turn them in both directions.. but if you're turning and it's not stopping after 1.5-2 turns, you're either turning the whole rod itself or the shock is faulty... more likely the first.
Old Sep 12, 2005 | 05:13 PM
c_buz's Avatar
Default Re: Koni install problem/question (da_truf)
Well it has been said many times over and I have to agree, Koni's instruction suck. Mine don't say test anywhere. I wish I had the time to scan them so you guys could see. Ohh well, at least I have no doubts now. Thanks a lot.
goodtrouble
Sep 5, 2007 08:01 PM
mtny
Suspension & Brakes
12
Sep 2, 2006 06:05 PM
Unjockable
18
Apr 18, 2005 12:03 PM
vteec
May 14, 2004 01:05 AM
integerkgsr
Feb 21, 2004 10:52 AM
