not your typical shock setting question...
New User
on the kyb agx shocks, let's say i have the setting at "8"...if i want to go to "2", do i have to turn it down or can i just turn it up and go to "1" and then "2"? will the shocks adjust itself properly?
hope all that makes sense.
New User
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">You cant turn it 8 directly to 1
It needs to go backwards 8765432</TD></TR></TABLE>
why is that?
on one of my shock, i think i turned it 8 directly to 1 or 2. i don't know if i did or not. that's why i'm asking if it's ok to do so.
why is that?
New User
Re: (chowmien)
not really that hard. but like i said, i think i turned it the other way by accident. that's why i'm asking if it's ok and will the shocks adjust accordingly.
well i have never had a prob turning it the wrong way but if you want to be safe just turn it all the way back around the "correct" way and it should be sweet
On most of the shocks Ive messed with (koni, tokico, some other ones I cant remember names of) the shock would not adjust past a certain point back to zero...just stops.
I mean the numbers arent digital, its all mechanical so I couldnt see how you could turn it from 8 to 1 and have it work correctly.
New User
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">On most of the shocks Ive messed with (koni, tokico, some other ones I cant remember names of) the shock would not adjust past a certain point back to zero...just stops.
I mean the numbers arent digital, its all mechanical so I couldnt see how you could turn it from 8 to 1 and have it work correctly.</TD></TR></TABLE>
that's what i thought but then i was messing with it earlier and i can make it go pass 8 and into 1. i didn't leave it like that though.
New User
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">did you check its rebound after you did that?</TD></TR></TABLE>
what do you mean? how do i check for that?
New User
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">like did it compress and extend as if it was set at 1 or like 8?</TD></TR></TABLE>
yes. it seemed normal.
Re: not your typical shock setting question... (Unjockable)
ad the fing directions that ome with em, theres a warning turn the only clock wise, so 1 2 3 4 5 6 7 8 , not *** backwards you can reck the valve or whatever and if you shocks blows because of it the dont warranty it, my friend did it to his,
Re: not your typical shock setting question... (Honda_project98)
Different type of shock but my tokico illumina's can be adjusted either direction. Then again theres only 4 settings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_project98 »</TD></TR><TR><TD CLASS="quote"> ad the fing directions that ome with em, theres a warning turn the only clock wise, so 1 2 3 4 5 6 7 8 , not *** backwards you can reck the valve or whatever and if you shocks blows because of it the dont warranty it, my friend did it to his, </TD></TR></TABLE>
so you CAN'T go counter clock-wise? so from 8, u gotta go to 1,2,3, etc?
so if i'm at 8, and want to go to 7, i gotta go all the way around?
Re: not your typical shock setting question... (boosted ek)
yup i have agx's too and i knwo some shocks dont matter but there is a warning one them to only go clockwise other the valve bs will get fucked up, i tried and clickin backwards i hard it doenst fell right oppoised to clicking the right direction fo if you at 6 wanna go for you must go 6 7 8 1 2 3 4
New User
just got off the phone with KYB tech support. the guy said it doesn't matter which way u turn it. the shocks adjusts itself.
RedHondaSi
05-14-2004 05:59 AM
