FUEL PUMP NOT PRIMING????????????
searched threads found nothing.
heres my problem. when i turn the key to the on position the fuel pump doesnt prime i checked the main relay to see if that was the problem and the relay is fine i even checked to see if the positive wire going to the fuel pump was getting power and im getting nothing i also replaced the fuel pump thinkin it was that at first is there any other things i can check farther back before the relay ohh even switched my ecu to see if that might help as well
thanx in advance
thanx in advance
same thing happened to me, check the ecu grounds which is on the t-stat housing. Also, wiggle on the engine harness, while trying to start it. I did everything you did, wiggled the engine harness, and it started, reason was, was because the harness wasn't in the correct/oem location, and it was pulling on one of the pins.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RHDej2. »</TD></TR><TR><TD CLASS="quote">any word?</TD></TR></TABLE>
thanx RHDEJ2 turns out it was fuse 24 i didnt even know there was a fuse for the fuel pump since its not listed thanx for the help
SPUNKYMUNKY
11
Mar 27, 2015 03:58 PM
