Tire Size
Old Feb 26, 2002 | 10:15 PM
O1 Coupe's Avatar
Default Tire Size
I have a 2001 Civic Coupe LX, and it came with 185/70/14. Sad, so I am picking up some rims soon. I went to a site that had Tire Size Calculator (http://www.miata.net/garage/tirecalc.html) which I found useful. The closest size to stock I got was 215/45/17. This should be no problem, right? It's *slightly* larger than stock and seems like it will throw off the speedo by 1%. The other option is 215/40/17, but I like the idea of having 45 series to fill the wheel arches more. Will this cause it to rub when I lower it 1"?
Old Feb 26, 2002 | 10:17 PM
O1 Coupe's Avatar
Default Re: Tire Size (O1 Coupe)
Oh, I just tried 225/40/17 on the calculator and its nearly perfect. Will this size work with my Civic? I know my car has bigger wheel well than the previous Civics, but I'm still errie...
Old Feb 27, 2002 | 08:14 AM
deepnite's Avatar
in a perfect world the calculator is fine..but in reality..id recomend 16 in wheels with 205/45 tires
Old Feb 27, 2002 | 09:23 AM
TurboSedan's Avatar
New User
Default Re: Tire Size (deepnite)
225 will rub, go with 215 max on a Civic.
Old Feb 27, 2002 | 09:27 AM
YodaIsGod
Guest
Posts: n/a
why do you want to make your slow car even slower with 17's? oh well...i guess for looks..
Old Feb 27, 2002 | 12:50 PM
O1 Coupe's Avatar
Default Re: Tire Size (YodaIsGod)
Well, I have a non-VTEC 115HP 1.7L mated to a 4speed automatic...
No, I didn't buy it for speed. I woulda bought a Stang for that!
Old Feb 27, 2002 | 01:00 PM
O1 Coupe's Avatar
Default Re: Tire Size (97CivicFerio)
Are you sure 225/40/17 will rub? It has a smaller diameter than 215/45/17.
allshownogo
Feb 23, 2008 04:18 PM
yaryar
Jan 10, 2008 07:11 AM
mikeaitken
Sep 11, 2007 01:41 PM
enzozenuni
Jan 29, 2007 10:53 AM
HuskerHybrid
Aug 26, 2005 06:58 PM
