Need help... car not starting
Old Sep 8, 2005 | 06:08 PM
makoto's Avatar
Default Need help... car not starting
I have a 89 four door lx with a d15b2. I have changed the timing belt recently, and it is slightly advanced... slightly ahead of the first mark on the pulley. It won't start now. It started, and ran for a minute or so, but now it won't start again. I put it to TDC for #1 cylinder... and the rotor (in the dizzy) is slightly past the #1 terminal on the cap. What could be the problem? Has fuel pressure... no code is flashing. The injectors are getting the right amount of voltage... blah blah blah. I think it might be the spring on the belt tensioner... I can't figure it out. I followed the book (a Helms or what ever, and even the book that the techs at dealerships use (for 89 wagon)) Please help... need to get it running since it is my daily driver.
Old Sep 8, 2005 | 06:24 PM
shawn_crx's Avatar
Default Re: Need help... car not starting (makoto)
probably adjust your timing.
Macnotiss
10
Oct 18, 2017 05:44 PM
green_si
18
Mar 3, 2010 03:24 PM
DaKINE-Ek
13
Aug 15, 2006 10:57 AM
WhitnBlue
Aug 14, 2001 10:45 AM
