need help asap engine cuts under strain HELP
Old Sep 8, 2005 | 03:02 PM
olschoolcivic's Avatar
Default need help asap engine cuts under strain HELP
I have a 91 civic 1.5 dx 5 spd when driving or going up hill engine cuts out,blows smoke and wont rev. I have already replaced cap,rotor,plugs,wires,dizzy,coil,air filter and every thing is brand new nothing used. car is driveable at low rpms but when i floor it to shift it coughs sputters puffs. I also checked comp. and I am above 180 all the way accross. If anyone has aclue please let me know thanks in advance
Old Sep 9, 2005 | 09:22 AM
crashoveride's Avatar
Default Re: need help asap engine cuts under strain HELP (olschoolcivic)
bump fot you
Old Sep 9, 2005 | 09:36 AM
Voodooboy520's Avatar
Check your O2 sensor. Any codes? It sounds like your running very rich.
Old Sep 9, 2005 | 02:48 PM
02 sounds interesting, check engine light on don't know how to check codes
Old Sep 10, 2005 | 03:37 AM
anyone?
Old Sep 12, 2005 | 03:01 PM
Si-REX89's Avatar
Default Re: (olschoolcivic)
02 sensor is the thingy (best description) on the Exhaust manifold w/ wires coming out of it. you may need to remove the manifold cover to get to the 02 sensor.
and the when the check engine light is on it means your running a code. look at the ECU (under the carpet on Passenger side or behind trim under dash beside passanger door) and its the metal box w/ alot of wires comming out of it. there should be a light on it and when you run a code it will blink a certain # of times. check how many times it blinks to determine which code and look that up online. -good luck-
Old Sep 12, 2005 | 03:05 PM
Suck my DX's Avatar
Default Re: (Si-REX89)
check ur timing
Old Sep 12, 2005 | 08:15 PM
Default Re: (Suck my DX)
I checked the codes and they came back with 1 and 16 I also checked the injectors and they are fine. anyone else? thanks
Old Sep 12, 2005 | 08:26 PM
Suck my DX's Avatar
code 1 is for your o2 sensor...it probably needs to be replaced and that is why u r running rich...
how did u check the injectors?
Old Sep 14, 2005 | 06:01 AM
I checked the injectors by reading the ohms but now i think i was wrong because i just changed the fuel filter and my plugs are soaked in gas and engine wont fire now ???????
Lethal001
Jun 28, 2008 05:55 PM
2kstreetcivic
Nov 8, 2005 05:26 AM
eatbieodie2
May 7, 2005 08:05 PM
Web_Head
Sep 29, 2004 08:25 PM
Hybrid
Aug 17, 2003 08:55 PM
