my check engine light is on need help
Old Apr 17, 2005 | 02:49 PM
eatbieodie2's Avatar
Default my check engine light is on need help
its throwing a engine code 74 i dont know what it is can anyone help. thanks
Old Apr 17, 2005 | 02:51 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: my check engine light is on need help (eatbieodie2)
74 - random misfire cylinder 4
Old Apr 18, 2005 | 12:11 AM
Default Re: my check engine light is on need help (wantboost)
what would cause that? and how do i fix it? thanx
Old Apr 18, 2005 | 12:46 AM
dustin's Avatar
check plug / compression test cyl 4
Old Apr 25, 2005 | 10:00 PM
Default Re: my check engine light is on need help (dustin)
do you know what check engine 65 is. thanks
Old Apr 26, 2005 | 07:15 AM
PrettyLude's Avatar
65 Secondary oxygen sensor heater
Old Apr 26, 2005 | 07:47 AM
adseguy's Avatar
Default Re: (PrettyLude)
https://honda-tech.com/zerothread?id=978933
for any future reference
Old Apr 27, 2005 | 10:37 PM
what would cause that to happen. thanks
Old Apr 28, 2005 | 04:36 AM
EE_Chris's Avatar
Default Re: (eatbieodie2)
Code 65 comes on because the heater element in the O2 sensor took a ****. To confirm, use a multi-meter and measure the resistance between the two black wires (unplug the O2 sensor from the main engine harness first) - should be 15-40 ohms.
Old May 7, 2005 | 08:05 PM
i_berger's Avatar
the light is on, how do i find out which code??
thanx
wonders702
Honda Civic (2001 - 2005)
Mar 17, 2011 11:33 PM
jayrod7
Jan 21, 2010 01:45 PM
greyejcoupe
Oct 3, 2009 10:48 AM
EK9_GRL
Oct 8, 2007 12:03 PM
