how to take off a the panel on the door
Old Sep 8, 2005 | 01:51 PM
TUNERboi's Avatar
Default how to take off a the panel on the door
does anybody know how to take of a panel on the driver door on a 92 honda accord lx
Old Sep 8, 2005 | 01:58 PM
gianinline's Avatar
Find the screws, I think there's only 4 of them.
And when removing the door panel, there's a wire the makes your handle be useful when you want to open the door.
For power windows, unplug the wires. Manual windows, I find very complicated, because there's a little "clip" the holds the "manual handle" to the door panel, and if you are not careful with that, you may brake that handle.
Old Sep 8, 2005 | 04:04 PM
deserthonda's Avatar
Default Re: how to take off a the panel on the door (TUNERboi)
first off lower window all the way, easier to pull up and remove panel.. remove screw for inner door handle. slide handle gently toward frt of car and pull out , unhook, rod clip, disconnect power door lock switch, remove handle, ,, remove plastic cover for power mirror it just pops out . it has clips, remove pocket screw where the window switches are, there are a bunch of clips that hold panel on, gently pry them off you will hear a popping nopise, disconnect plug at rear bottom of panel for door lite or you will rip thw wires off. pull up partialy on panel , now u can see and disconnect wiring for power windows,,,
casper.hughes
Oct 12, 2008 06:33 PM
206civic
Jan 8, 2005 11:43 AM
eddie1681
Feb 24, 2003 10:33 PM
teg95
May 22, 2002 01:16 PM
Thrillhouse
Apr 14, 2002 11:30 AM
