car wont start after I took of a spark plug
Old Sep 8, 2005 | 01:09 PM
h kid's Avatar
Default car wont start after I took of a spark plug
well i have a d15bvtec turbo engine in my hatch and i recently started to here detonation in my car so I decided to retard my timing, after that the car started fine and the idle was fine also. As I was standing in front of my motor I decided to unplug the spark plug wire on piston #1(just to see how it would idle) and it proceeded to shut down in a couple of seconds, I put it back on and tried to turn the car on but know the it wont start. Has any body ever had this happen or do you know what is causing this, all help would be greatly appreciated.
Old Dec 5, 2005 | 04:06 AM
EFvtec Yo!'s Avatar
Default Re: car wont start after I took of a spark plug (h kid)
Bump it up. I know this is old but it just happend to me yesterday.
Old Dec 5, 2005 | 08:57 AM
EFvtec Yo!'s Avatar
bump
Old Dec 5, 2005 | 09:19 AM
574-240sx's Avatar
flood the cyl possibly? Take the plug out and is it covered in fuel. How long did you have it pulled off.
Old Dec 5, 2005 | 09:54 AM
EFvtec Yo!'s Avatar
man, it was off for like 3 seconds. he went to crank it and it died. So we put the plug wire back on that fell off and nothing. We put a new coil in it, nothing. Swapped ecu's and dizzys off of a running car and still nothing. Help anyone! Car is a 2000 EX obd2-obd1 conversion. LS/VTEC
Old Dec 5, 2005 | 10:02 AM
dpkelly's Avatar
Default Re: (EFvtec Yo!)
Most likely flooded. Just press the gas pedal as you start it. This will cause a spray of gas which will ignite and burn off the remaining gas. Good luck.
Old Dec 5, 2005 | 10:32 AM
Luserkid's Avatar
Default Re: (dpkelly)
Disconnect your batt, take out your plugs and let them sit out of the motor for 15 mins. Put them back connect the batt. and try again.
Old Dec 5, 2005 | 11:36 AM
EFvtec Yo!'s Avatar
preciate the responses. I will let you guys know what happends when i get off and go work on it again.
Old Dec 5, 2005 | 11:46 AM
VTAKKK!!'s Avatar
each plug wire contains around 40,000 volts per spark and by taking that plug wire off you back fed all that power to the ignition module inside of your distributor and burnt it out
heres how to test and replace it
https://honda-tech.com/zerothread?id=1430824
mr_munro
Jul 25, 2012 10:43 PM
Kelb
14
Aug 20, 2007 06:00 PM
the.hamburglar
Apr 21, 2007 12:45 PM
4doorcivic16
Mar 4, 2007 05:07 PM
kreative
24
Nov 14, 2006 11:23 PM
