96 ls motor obd1 or obd2
Old Sep 8, 2005 | 09:18 AM
Sik Wit It Hatch's Avatar
Default 96 ls motor obd1 or obd2
found a 96 ls motor but i have a 92 hatch which i believe is obd1 is this motor obd1 or obd2 if its obd2 will it require a lot of work to put it in my car to switch it to obd2?
Old Sep 8, 2005 | 09:23 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: 96 ls motor obd1 or obd2 (Sik Wit It Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sik Wit It Hatch &raquo;</TD></TR><TR><TD CLASS="quote">found a 96 ls motor but i have a 92 hatch which i believe is obd1 is this motor obd1 or obd2 if its obd2 will it require a lot of work to put it in my car to switch it to obd2?</TD></TR></TABLE>you can put it in your car but will need; 94-95 ls manifold(complete), ls obd-1 distributor and all the other parts for the swap
Old Sep 8, 2005 | 09:30 AM
Default Re: 96 ls motor obd1 or obd2 (2FAST4U831)
thanx a lot so i wont need to go crazy getting parts just the tranny,ecu,axels,mounts,wiring harness and the things you mentioned
Old Sep 8, 2005 | 09:52 AM
I Have an STD's Avatar
wrenchin'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 &raquo;</TD></TR><TR><TD CLASS="quote">you can put it in your car but will need; 94-95 ls manifold(complete), ls obd-1 distributor and all the other parts for the swap </TD></TR></TABLE>
um... no. you need to re-wire the dizzy and use the obd2 manifold. get our story straight.
and no, use your stock wiring harness
Brett
Old Sep 8, 2005 | 09:58 AM
Default Re: 96 ls motor obd1 or obd2 (I Have an STD)
is it hard to rewire the dizzy? i mean can i do it myself or just bring it to someone to do it for me. i can use my stock harness theres some good news thanx.
Old Sep 8, 2005 | 11:35 AM
bradykiller's Avatar
No it's not hard at all.
I did with mine when i used my 99 DX harness, and attached an odb2 b-series dist to it.
92integraVTECgsr
Jun 1, 2008 04:30 PM
5poonhatch
Jul 21, 2006 01:39 PM
TurboTegB
Dec 18, 2004 01:57 AM
SPOONfdEK
May 27, 2003 06:32 PM
95hbMatt
Jun 18, 2002 03:03 AM
