how can i clear these two codes
Old Sep 7, 2005 | 06:52 PM
racingant's Avatar
Default how can i clear these two codes
my setup in my 91 civic si is a jdm obd0 b16 swap i'm get the code for a 2nd o2 sensor i only have one o2 sensor do i have to put another one
the next code i'm getting is for my knock sensor do i have to do u think that because of the 02 sensor i can be getting that code or u think it my knock sensor, if so can i use the knock sesnor off my single vtec swap
Old Sep 7, 2005 | 11:08 PM
cdgcrx91's Avatar
Default Re: how can i clear these two codes (racingant)
As far as i know when running the obd0 ecu you do need the second 02
For your knock sensor, check the wiring for it to your ecu, the pin may be different, you can get a chart on hasport. Im not positive on this but its something you can look at.
Old Sep 9, 2005 | 04:55 AM
racingant's Avatar
Default Re: how can i clear these two codes (cdgcrx91)
i was told there is something that i can buy to trick the ecu to think there is a 2nd o2 sensor is that true
Old Sep 9, 2005 | 05:04 AM
Mr Synister's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant &raquo;</TD></TR><TR><TD CLASS="quote">i was told there is something that i can buy to trick the ecu to think there is a 2nd o2 sensor is that true</TD></TR></TABLE>
chip your ecu
Old Sep 10, 2005 | 05:34 PM
racingant's Avatar
Default Re: how can i clear these two codes (Mr Synister)
i chip my ecu with a low cash chip and it still the same
JDMF22B
May 13, 2005 02:17 PM
m3bluegsr
Sep 3, 2004 07:59 AM
davken1102
Feb 6, 2004 10:42 AM
EG6[B16A1]
Oct 19, 2003 11:22 AM
1.8EG-T
Nov 5, 2001 12:08 PM
