itb owners/ users. how are you routing/ re-routing your coolant lines?
Old Sep 7, 2005 | 06:47 AM
Black R's Avatar
25 Year Member
Default itb owners/ users. how are you routing/ re-routing your coolant lines?
iirc, I just capped them all off and using the hondata IM gasked in the RACE install, I capped the large fitting coming off the head and t'd that line back into the heater core lines...
I noticed that my itb's still get quite warm after driving..... even with the hondata IM gasket.....
How are your coolant lines routed now?
Modified by Black R at 9:02 PM 9/7/2005
Old Sep 7, 2005 | 01:50 PM
DavidR's Avatar
Default Re: itb owners/ users. how are you routing/ re-routing your coolant lines? (Black R)
Hmm, that is the crank case breather for VTEC blocks. Are you sure you capped that one? There is also a fitting on some blocks that is lower and to the left of that fitting which is the water return for the factory oil cooler.
Old Sep 7, 2005 | 05:04 PM
Black R's Avatar
25 Year Member
Default Re: itb owners/ users. how are you routing/ re-routing your coolant lines? (DavidR)
sorry, i posted the wrong pics earlier.
I have corrected my first post.
It's the fitting on the water pipe that I capped. And the port on the IM closest to the distributor.....
Old Sep 7, 2005 | 08:26 PM
DavidR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">sorry, i posted the wrong pics earlier.
It's the fitting on the water pipe that I capped. And the port on the IM closest to the distributor..... </TD></TR></TABLE>
Ahh. So, the cap you used, is it a cap suited for vacuum or coolant? Most caps I've seen in autoparts stores are plain low grade rubber, no reinforcement.
Old Sep 7, 2005 | 11:23 PM
revolt_allmotor's Avatar
yeah be really careful with this, I have those ports capped and one of the caps failed recently causing me to lose a bunch of coolant and overheat
I've heard you can unscrew that fitting on the intake manifold and screw in a plug but I haven't tried it yet...
Old Sep 8, 2005 | 05:11 AM
Black R's Avatar
25 Year Member
Default Re: itb owners/ users. how are you routing/ re-routing your coolant lines? (slowegxxrevolt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowegxxrevolt &raquo;</TD></TR><TR><TD CLASS="quote">yeah be really careful with this, I have those ports capped and one of the caps failed recently causing me to lose a bunch of coolant and overheat
I've heard you can unscrew that fitting on the intake manifold and screw in a plug but I haven't tried it yet...</TD></TR></TABLE>
I'm having that same fear.....!
I would like to remove the brass fittings and put plugs in instead. I have no idea how I could do that to the water pipe though.....
integra3586
Sep 27, 2012 08:32 PM
Mr HYDE
Oct 2, 2006 06:07 AM
endlessdv
Jan 5, 2006 10:38 AM
*Boostwerks*
May 19, 2005 01:34 PM
Darkteg
Oct 25, 2002 09:00 AM
