NO VTEC, ALREADY SEARCHED NEED HELP!!!!
Old Sep 7, 2005 | 06:18 AM
jdmteg96's Avatar
Default NO VTEC, ALREADY SEARCHED NEED HELP!!!!
okay well my vtec isn't kicking in. its a h22a4 in a 92 civic cx hatch. i already took off my solenoid and cleaned it out and vtec still does not kick in. i've waited for the car to warm up and i am sure i have enough oil and i have no major leaks. i was wondering if anybody could help me with the wiring as far as which wires go to the ecu from the vtec solenoid. any help will be appreciated
Old Sep 7, 2005 | 10:43 AM
jdmteg96's Avatar
Default Re: NO VTEC, ALREADY SEARCHED NEED HELP!!!! (jdmteg96)
bump
Old Sep 7, 2005 | 12:48 PM
IHateJDM's Avatar
what ecu are you running? If p13,
Solenoid (one wire plug) goes to A4
Pressure switch signal (usually blue) goes to D6
Pressure switch ground (usually black) goes to A26
If you are running a p28, the wiring is the same, but the PS ground does not need to go to the ecu, it can be grounded on the head.
Old Sep 7, 2005 | 07:00 PM
jdmteg96's Avatar
Default Re: NO VTEC, ALREADY SEARCHED NEED HELP!!!! (IHateJDM)
its a p28 and thanks for the help. i'll be sure to look at thing first thing in the morning. any other reasons why vtec wouldn't be kicking in?
Old Sep 7, 2005 | 09:02 PM
SL0WEGG's Avatar
are you getting a check light? if so check the code and let us know what it is.
Old Sep 8, 2005 | 12:34 AM
jdmteg96's Avatar
Default Re: NO VTEC, ALREADY SEARCHED NEED HELP!!!! (boostedej1)
the only check engine light i have right now is a code 3 and code 7. tps and map sensor. could that have anything to do with it?
Old Sep 8, 2005 | 05:36 PM
lsvtecracer's Avatar
If you have code 3 and 7 then you might have switch the two plug harness by accident. It would have an affect on vtec. Double check the wiring to make sure you plug them up correctly then reset the ecu. After that, take it out for spin and see if vtec work.
Old Sep 9, 2005 | 12:00 PM
jdmteg96's Avatar
Default Re: NO VTEC, ALREADY SEARCHED NEED HELP!!!! (lsvtecracer)
i'll try that and get back to you. just in case that isn't it does anybody have a how to: on how to wire a h22 in a cx hatchback. im not totally sure if the wiring is correct now.
Old Sep 9, 2005 | 12:36 PM
SL0WEGG's Avatar
thats kind of weird. if you switched tps and map. the car wouldnt start, would it?
Old Sep 9, 2005 | 03:59 PM
On some car it will start and on some it won't. It will definitely run like crap when it does though.
Manny 77
30
Oct 13, 2009 12:46 PM
IHEARTMYHONDA91
12
Jul 12, 2009 07:02 PM
92 hatch d15b JDM
10
Feb 15, 2007 12:30 PM
jbscivichb92
Aug 16, 2004 05:13 AM
ltho1998
Aug 21, 2003 08:08 AM
