greasing the axles
when you guys install new axles, do you grease up the splined ends or the transaxle openings or at the half shaft joint?
i already put the drivers side axle and suspension together and then i got stuck on the passenger axle. i can't pop the splined side in past the spring clip. so i went to the haynes manual and see that it mentions greasing up these areas upon reinstallation.
i dont recall ever doing that before, but then again, i'm no expert. is this necessary? do you guys do this?
thanks!
thanks!
thanks. anyone else? im' off work for the day, takin my wife to stanford for a follow up. hopefully there will be more replies. i'm pretty much not moving forward on the build until i square away this issue of greasing the axle splines. btw antiseize seems like a great idea
Death_to_Thieves
Aug 24, 2004 09:39 PM
