Suspension & Brakes Theory, alignment, spring rates....
Front Forks
Old Sep 6, 2005 | 08:23 PM
LaOstha's Avatar
Default Front Forks
What front forks can i use that are shorter than my stock ones (ej1,eg) so i can lower my car in the front a lil with out sacraficing loss of suspension travel.
Old Sep 7, 2005 | 01:23 PM
TunerN00b's Avatar
Default Re: Front Forks (LaOstha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaOstha &raquo;</TD></TR><TR><TD CLASS="quote">What front forks can i use that are shorter than my stock ones (ej1,eg) so i can lower my car in the front a lil with out sacraficing loss of suspension travel.</TD></TR></TABLE>
Jack up the car and place on jackstands. Loosen the fork bolt (don't remove) that holds the shock in place. Jack up the fork, so the spring pushes the shock body further into the fork. When the shock sticks out the bottom, tighten the bolt again. Repeat on the other side, but get both even.
Or, just modify the top hats for more suspension travel. Or buy the GC extended top hats.
Old Sep 7, 2005 | 03:12 PM
LaOstha's Avatar
Default Re: Front Forks (TunerN00b)
i have coilovers and its already all the down in the fork like u said. I have omni sports can i put gc top hats on em?
Old Sep 7, 2005 | 03:26 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaOstha &raquo;</TD></TR><TR><TD CLASS="quote">i have coilovers and its already all the down in the fork like u said. I have omni sports can i put gc top hats on em?</TD></TR></TABLE>
youre telling us you have omnipower coilovers and still not happy with your drop and are looking for extra ways to lower it? why am i not surprised...
i dont think the GC top hats will work for you. you would have to check the OD of the shock diameter to see if it will fit inside the top hat. if it doesnt fit, it does nothing for you.
Old Sep 7, 2005 | 05:58 PM
LaOstha's Avatar
Default Re: Front Forks (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">youre telling us you have omnipower coilovers and still not happy with your drop and are looking for extra ways to lower it? why am i not surprised...
you.</TD></TR></TABLE>
The drop of the omni sports only let me go so far down in the frront with out letting the spriong loose. right now with the spring ont the chock with a lil preload i have a 2 finger gap and would like to have a no finger gap. so im baisically tryin to find a way to lower it a lil more
Old Sep 7, 2005 | 11:08 PM
Tyson's Avatar
yeah, i hear you. them omnipowers were not designed properly. thats a fact.
i think your best bet is to just give up the preload and start to lower the spring perch.
actually, i say just dump the omni's. theyre pretty worthless. thats just an opinion.
Old Sep 8, 2005 | 09:34 AM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">yeah, i hear you. them omnipowers were not designed properly. thats a fact.
actually, i say just dump the omni's. theyre pretty worthless. thats just an opinion.</TD></TR></TABLE>
I wouldn't worry about preload, anyone with the Koni/GC combo doesn't have preload anyway, and they do fine.
Old Sep 8, 2005 | 10:42 AM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldn't worry about preload, anyone with the Koni/GC combo doesn't have preload anyway, and they do fine.</TD></TR></TABLE>
I agree. Preload doesn't really do anything for you. If your really woried about it, you could get a set of helper spirngs & locator collars. Helper springs take up the slack when the suspension droops, but are totaly compressed when the car is on the ground...
Expect to pay about $200+
Old Sep 8, 2005 | 12:11 PM
slammed_93_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">
I agree. Preload doesn't really do anything for you. </TD></TR></TABLE>
on a street car i agree 100%, but what people need to relize is that when we talk about preload not doing anything we are talking about a properly designed damper. Unlike the omnis that have EXTREMLY small area of piston travel. And what happens if you don't have preload on the omni's? you will run out of travel and bottom them out.
Old Sep 8, 2005 | 12:52 PM
LaOstha's Avatar
Default Re: Front Forks (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">on a street car i agree 100%, but what people need to relize is that when we talk about preload not doing anything we are talking about a properly designed damper. Unlike the omnis that have EXTREMLY small area of piston travel. And what happens if you don't have preload on the omni's? you will run out of travel and bottom them out.</TD></TR></TABLE>
thats what im scared of if i lower the spring perch, bottomming out all the time. I think imma just lower the spring so to get my ride height and see how it is for a day or 2 sincce the roads are pretty smooth where i live.
mikeneamtu
Suspension & Brakes
Jun 28, 2013 09:42 AM
alfaaay
17
Feb 3, 2008 10:55 AM
ZeroTorque
Mar 15, 2005 08:03 PM
sporkcrx
Jun 22, 2003 10:02 AM
CXHatchback
Jun 5, 2003 09:22 PM
