Hey u b20/b18c1 vtec people.....hows it going for u?
hey, i just got my b20vtec w/gsr head done...w/hondata s200....and litttle more, like clutch.....but i was just wondering how everyones is holding up......and also, post ur build-up, like what u got done to it...i need some ideas that i can build on..thanks..
you don't NEED one.....but it is nice to have for insurance
block guards do exactly what their name states..........guard the block
it would be a good idea for applications with weak sleeves,such as a B20
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A4_egHatch »</TD></TR><TR><TD CLASS="quote">you don't NEED one.....but it is nice to have for insurance
it would be a good idea for applications with weak sleeves,such as a B20</TD></TR></TABLE>
the point of sleeving a block is so you dont need to use a block guard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-TanK978 »</TD></TR><TR><TD CLASS="quote">I have an ls/v-tech 84.5/ 2.0 if that counts
13.1 endyn
Eagle rods
Block guard
B16 head
JDM itr internals ex. valves they are ferra
JDM exhaust mani. & intake mani
Nothing crazy wish it was a lil faster!
this is also kinda weird, he has JDM itr internals that are ferrea?
13.1 endyn
Eagle rods
Block guard
B16 head
B18b bottom ls rods/ ls crank/ OS CTR pistons(.25)/ arp rod bolts
GSR tranny with 4puck clutch
B18C1 head w/ skunk2 springs and TI retainers/ EF-1 M23 cams (JUN3 equivelent)
TUNING: Cam gears/ JDM P30 ECU/ Apexi VAFC
Compression approx. at 12.4:1
right now it runs amazing but it has a STOCK B20 header Stock CIVIC DX Cat and 2" piping to a high flow muffler.
Im looking to get a 2.5" 4-2-1 header test pipe and 2.5" catback exh.
Because of the exhaust restrictions when vtec hits at 5100rpm the only difference is engine noise up until about 6500rpm, then it begins to fly. i usually find myself shifting anywhere from 7500-8000rpm now because of lack of top end power. once it is complete i should be redlining at 8500rpm with power all the way.
Oh yea and it runs like a stock honda, never hesitates, never smokes, never doesnt start on the first turn and best of all gets 30MPG!!!!
i am in the middle of getting all of my parts for lsvtec i allready have a new ls water pump from when i was going to do ls turbo, is that safe to run or should i just sell it and get a gsr one. i know the gsr one has less teeth on it so it doesn't spin so fast during high rpms but has anybody had any problems running the ls water pump and revving to 8k rpms?
zer0-psi missunderstood
took internals from a jdm itr head an put it back into another b16 head . so i took out the
cams
valve springs
and ratianer
and did a 3 angle valve job and bought a new set of valves that are made from Ferrea
cams
valve springs
and ratianer
sounds good guys..thanks....could some1 help some1 out....like what setup should i consider...here is my goal:
i want reliablity, being my daily driver
im going NA
want full throttle response
11:1 compression..im thinking it should be safe for streets, and use 91oct
This is not a drag car, a car i use everyday
I got these in miind
B16 w/lsd tranny
jun/skunk2 head package..im not sure where i want to go.. heard bad vibes about skunk2
over sized throttle body....jdm 4-1 headers......
As for the bottom....what pistons/rods, would u recomend..im thinking eagle rods,...but as far as pistons, do i want smooth head, or domed..and what brand..and do i need to re-seelve to make bottom stronger . also, i know arp rod bolts r a must..im going to keep my crank b20....but neways..ne help would be apperciated....my budget is 2500$ right now........so where should that take me??? thanks.
this is what i already got
b20/b18c1 stock internals
comptech clutch
RSR cat-back exhust
MSD wires
Akimoto cold air
short shifter
Hondata IM heatsheild gasket
all new gaskets, from the swap, new valve seals, and i got valve adjustment
partily tuned(tuned w.laptop while driving on streets)with Hondata s200
im going NA
B16 w/lsd tranny
comptech clutch
RSR cat-back exhust
MSD wires
Akimoto cold air
short shifter
heres what I got:
b16 head
-crower stage 3 cams
-rocket valve springs/retainers
-mild p&p
-skunk2 IM
-str 68mm tb
-rc 310 injectors
-str fuel rail
-aem fpr
ls block
-11:1 pistons (usdm type r)
-stock rods
-stock crank
-new bearings (forgot name of brand)
tranny
-ys1 cable
-type r lsd
-exedy stage 2 clutch
-act lite flywheel
exhaust
-dc 4-2-1 header
-omnipower test pipe
-2.5" pipe
-skunk2 muffler
its working out pretty good for me, I only had minor problems (which were my bad). I'm gonna go b20 very soon, but i'm debating on wether to stay all motor, or boost.
b16 head
-mild p&p
-skunk2 IM
-str 68mm tb
-rc 310 injectors
-str fuel rail
-aem fpr
ls block
-stock rods
-stock crank
tranny
-ys1 cable
-type r lsd
-act lite flywheel
exhaust
-dc 4-2-1 header
-2.5" pipe
-skunk2 muffler
B20B4 block with stock crank
ACL race bearings
Eagle rods
Wiseco 10.8:1
Block guard
Endyn breather kit
GE VTEC kit
Stock B16A head
DC Sports 4-1 header
2.5" exhaust straight back
Short ram intake
Autometer mech. oil pressure guage
B&M FPR and fuel guage. . .run 50psi @idle
Hondata S200 (untuned)
Ok so far, has about 98miles now, don't drive it anymore, waiting on tune, currently parked.
ACL race bearings
Eagle rods
Wiseco 10.8:1
Block guard
Endyn breather kit
GE VTEC kit
Stock B16A head
Short ram intake
hey diety..........what were ur problems u had??..and also...for Rude...whats ur hp and tq going to be u think??..ur setup is similar to what i have in mind....keep me up to date w/urs..sounds like what i wanan do..except have higher compression...thanks my email is acro_ryder@yahoo.com.............thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timesnap »</TD></TR><TR><TD CLASS="quote">B18b bottom ls rods/ ls crank/ OS CTR pistons(.25)/ arp rod bolts
raise ur VTEC up and it might help u out. when VTEC opens up and sounds really loud but the car aint moving fast, its usually cuz VTECis set too low. u ever took the car to a dyno? u will see the power drop when VTEC kicks in at 5100 until it reaches like what u said, around 6K. i would set VTEC to engage at around 5.6-5.8K to see how the car feels
right now i have
b20b block
cleaned, bored and rehoned 84.5mm
weisco pistons 12.5:1
stock rods
arp rod bolts
obd 1 gsr head
portflow and itr springs
Omni power ti retainers
stock cams
b16 ys1 tranny
b16 clutch and flywheel
havent put it together set. its just sitting in my garage.
b20b block
stock rods
arp rod bolts
obd 1 gsr head
stock cams
b16 ys1 tranny
my set up: ( dayli driver)
B20Z2 over zised to 85 MM by RS Machines
IB spec 11:8.1 wiseco pistons
GSR Head
skunk2 stg II cams and valve springs
Portflow 3 angle valve job and retainers
eagle H beam rods
KNife edge cranck
ACL bearings
AEBS IM
68MM TB
I havent tuned it yet but i hope to make some good numbers
GSR Head
eagle H beam rods
KNife edge cranck
ACL bearings
AEBS IM
68MM TB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeityDA9 »</TD></TR><TR><TD CLASS="quote">heres what I got:
ls block
i thought usdm itr's were 10.8 comp??,...
ls block
sounds good...got some ideas now....mie4h2....whats ur specs on the weisco pitsons...and where did u get 'em at..im looking to run those too....84.25mm size...re-sleeve....also, i think that will give me 11:8cp..will 91oct be good gas for that?
JDMroyEG5turbo
Mar 13, 2006 01:18 PM
