b20 from a b18?
Old Aug 13, 2008 | 07:19 PM
weev's Avatar
Default b20 from a b18?
Can I resleeve my b18c1 block to make it a b20? And which head do I put on it? I dont have a gsr or a b16 head so ill have to buy one?
Old Aug 13, 2008 | 10:38 PM
JDM_CRX_PLEASE's Avatar
Default Re: b20 from a b18? (weev)
a b20 is basically a bored LS motor.
its non vtec.
and a b18C1 block is a GSR block.
i dont know what your trying to get at.
you wanna make it a b20? what do you mean?
you can put on either GSR or b16 head but
b16 head + GSR block = poor mans type R
gsr head + gsr block = GSR motor
Old Aug 14, 2008 | 04:57 AM
na+b18c_hatch's Avatar
i think what he means is, can he bore his b18c1 out to be 2.0L...
Old Aug 14, 2008 | 05:05 AM
hpimichael02's Avatar
Default Re: (na+b18c_hatch)
what kind of HP gains will we get if we bore our LS out to 2.0L and have a 11.5/1 comp. ratio?
Old Aug 14, 2008 | 05:09 AM
Default Re: (hpimichael02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpimichael02 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of HP gains will we get if we bore our LS out to 2.0L and have a 11.5/1 comp. ratio?</TD></TR></TABLE>
it would probably be cheaper and def. easier to just buy a b20 long block
Old Aug 14, 2008 | 05:54 AM
ivan93egreppin210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weev &raquo;</TD></TR><TR><TD CLASS="quote">Can I resleeve my b18c1 block to make it a b20? And which head do I put on it? I dont have a gsr or a b16 head so ill have to buy one?</TD></TR></TABLE> hell yea you can resleeve and bore it out. this would take you from 81mm pistons to 84. it would be way stronger than a gsr and more reliable due to the sleeves. are you boosting or all motor?
Old Aug 14, 2008 | 04:37 PM
weev's Avatar
Default Re: b20 from a b18? (ivan93egreppin210)
im going all motor. where can i get the sleeves and do you know about how much it costs to have a block relseeved like that? Do you know of any good threads about a b20 build similar to this? I want to use a b16 head on a sleeved b18c1 gsr block bored to b20 size(84-84.5). what type of pistons should i use? is there a type r style high compression piston in this size?
Old Aug 14, 2008 | 04:44 PM
cetcivic's Avatar
no one wants to hear the truth
ive been thinking of doing the same,but,it requires a crank and rods from an LS OR B20(to get 2.0L)..you can get your block resleeved and b20 type r pistons at rsmachines.com
Old Aug 15, 2008 | 11:44 AM
use b16b pistons woot woot. high compression motor :]
just search b20vtec or something and you can read up about it.
and yah its cheaper just to get a b20 and sleeve it instead of boring and sleeving a LS motor.
Old Aug 16, 2008 | 11:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weev &raquo;</TD></TR><TR><TD CLASS="quote"> I want to use a b16 head on a sleeved b18c1 gsr block bored to b20 size(84-84.5). what type of pistons should i use? is there a type r style high compression piston in this size?</TD></TR></TABLE>
dont buy a b16 head. gsr will give you higher compression. send your block to rs machine.
here is a quote off another website. i am in no way an rs machine rep and if this post is against the rules, mods feel free to delete it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsmachines;3039871 &raquo;</TD></TR><TR><TD CLASS="quote">RS Block Sleeving Special ONLY $850 free shipping
Special Applys to All B-series, D-series, H-series, K-series etc 4cly applications
Just send us you block, we will sleeve it final bore and ship it back to you for Only $850 out the door.
Enjoy RS Machines Magnum Sleeves
D-series block $100 additional charge for block notching </TD></TR></TABLE>
Old Aug 17, 2008 | 12:04 AM
northemt88's Avatar
i would say go for it and do the bored gsr so that way cops cant say anything and it will just look like a gsr with the hood popped
Old Aug 17, 2008 | 12:19 AM
northemt88's Avatar
https://honda-tech.com/zerothread/1676914
Old Aug 17, 2008 | 05:36 AM
one bad dx's Avatar
Default Re: (JDM_CRX_PLEASE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE &raquo;</TD></TR><TR><TD CLASS="quote">use b16b pistons woot woot. high compression motor :]
and yah its cheaper just to get a b20 and sleeve it instead of boring and sleeving a LS motor.</TD></TR></TABLE>
How is it cheaper if he already has a 1.8 bottom end?
If you already have the block just send it out, you can find 42,086,900 threads on B-series build ups utilizing the search button on your top right.
B20/B18 blocks if they are non-vtec are identical minus the final bore 81x89 vs. 84x89 so take your pick.......if your getting it sleeved it does not matter which one you start with as they will both end up the same in the end.
Old Aug 17, 2008 | 11:29 AM
Default Re: (one bad dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one bad dx &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> correct but the ref in cali does not see it the same. if he wants a legal 2.0 b series,the b18 has to be sleeved and bored. the b20 is not an option.
Old Aug 17, 2008 | 03:51 PM
all-mtr-teg's Avatar
[QUOTE=JDM_CRX_PLEASE]use b16b pistons woot woot. high compression motor :]
and yah its cheaper just to get a b20 and sleeve it instead of boring and sleeving a LS motor.[/QUOTE]
You need to rethink your statement. How will the price be cheaper to buy and resleeve a B20 vs. buying and resleeving an LS. It would be cheaper for the OP to keep his GSR block, sleeve it, bore to 84mm and slap a vtec head on there. That saves him money from having to buy another block and from buying a LSvtec kit as well.
x_doug-x
Oct 28, 2010 12:21 AM
rafig2001
Sep 24, 2010 09:52 AM
Bullet113
Apr 18, 2006 10:36 AM
A.E Motoring
17
Dec 1, 2005 11:20 PM
bsemeyn
Sep 30, 2003 06:15 AM
