d16z6 swap HELLLLPPPP PLEASE IDLE IS REALLY BAD!!!
did you spary carb cleaner everywhere to check for leaks? also check your idle screw on your TB. also have you checked the cleanliness around the throttle plate and idle air valve? just some things to check
ye we sprayed carb cleaner no changes, we messed witht he idle screw didnt lower rpm, and we cleaned out the thortle body still giving me the same problems. if we plug the throttle body with a towl, then the rpm drops to 1000 and stayes steady.
Jonathan_ED3
Jan 13, 2009 03:15 PM
hatch808
Jun 9, 2003 03:56 PM
