Throttlebodies and other parts interchange (B series)?
Old Feb 26, 2002 | 03:22 PM
Bnjmn's Avatar
Default LSVtec questions
I'm using a '95 B18B1 engine, '93 LS tranny, and planning on a 99 Si head. Here are the questions-
-Which starter- '93?
-Will a 94-95 Del Sol Distributor work?
-'92+ flywheel and clutch, correct?
- LS manifold sensors idle mechanisms will transfer to Si head?
- Any B series header or are B16 and B18C headers different?
Thanks very much
Ben
[Modified by Bnjmn, 11:17 PM 2/26/2002]
Old Feb 27, 2002 | 08:02 AM
crxfactor1991's Avatar
Default Re: LSVtec questions (Bnjmn)
what car is this going in?
yes on the clutch
the only diff in the headers is possibly the # of o2 sensor bungs
the sensors should swap over from the ls to the si head
the starter will work
the dist, im not sure of, it might, but it might not, can you get one from a 99 si?
Old Feb 27, 2002 | 08:16 AM
Bnjmn's Avatar
Default Re: LSVtec questions (crxfactor1991)
I'm going OBD-1 in a 91 CRX DX, so no '96+ distributors.
On the starter- will a '94-'95 work as well? They seem to be cheaper.
Thanks
Ben
stilhyperformance
Sep 7, 2012 03:10 PM
s2k_al
Feb 16, 2005 05:40 AM
InTeGrA B18b1
Oct 21, 2003 07:01 AM
wm5holla
Sep 25, 2003 06:24 AM
DubyaAye
Aug 31, 2003 08:12 PM
