Suspension & Brakes Theory, alignment, spring rates....
Sway bar question
Old Sep 6, 2005 | 01:38 PM
eg6hatch's Avatar
Default Sway bar question
I have a blox Sway bar on my 97 GSR and it is just bolted on in teh center to hold it up, i am wondering where i can get the end links that acutally hook it to the control arm( i think that is what it bolts to)?
Old Sep 7, 2005 | 07:11 AM
eg6hatch's Avatar
Default Re: Sway bar question (eg6hatch)
noeone knows?
Old Sep 7, 2005 | 09:25 AM
216.226.142.95:27016's Avatar
im not familiar with the setup but most swaybar incorporates stock endlinks or endlinks are provided. what are you doing for subframe reinforcement, guessing that this is a bigger sway bar than stock?
Old Sep 7, 2005 | 10:13 AM
eg6hatch's Avatar
Default Re: Sway bar question (216.226.142.95:27016)
yes it is bigger, well i dont know, what is the best setup i can get, i have not had a aftermarket sway bar before, and not it did not come with the kit, adn the stocks wont work
Old Sep 7, 2005 | 01:18 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6hatch &raquo;</TD></TR><TR><TD CLASS="quote">yes it is bigger, well i dont know, what is the best setup i can get, i have not had a aftermarket sway bar before, and not it did not come with the kit, adn the stocks wont work</TD></TR></TABLE>
If it did not come with new endlinks, and the stock ones won't work, sounds like its time to contact the manufacturer. Sorry I can't be more helpful, my Comptech bar came with new endlinks.
Old Sep 7, 2005 | 03:09 PM
RedEK9's Avatar
Default Re: Sway bar question (TunerN00b)
Most sways should come with endlinks, so I would contact your manufacturer. If worst comes to worst you can get endlinks with bushings at Pep Boys, but you will still need some miscellaneous hardware to finish it off.
JDMCRX
Suspension & Brakes
Jun 14, 2008 03:53 PM
remoer
Suspension & Brakes
May 20, 2008 04:45 PM
T"u"Rtle
10
Feb 27, 2006 02:31 PM
crazy_ham
Jun 8, 2003 07:49 AM
crazy_ham
Apr 6, 2003 08:59 AM
