EF hatch with b16a obd 0 swap vtec problem
hi everyone,
I have a EF with a b16a obd 0 in it. Its ran fine for a long *** time. it has msd, cams, pistons...internals ect ect...
suddenly vtec stopped working. when i hit 5,000rpm (chip) the motor bogs nasty. there is no cel, and no blinking from the ecu. i have over 90psi oil pressure at 5k rpm. i switched vtec solinoid and pressure switch, and it still dont work. my friend from premier motorworks thinks its the ecu. but again, no cel, no blinking, and plenty oil pressure. i upped the fuel pressure too, nothing works. any ideas? oh yeah, i checked timing too, that was on too
btw, i did continuity test on the wiring and everything is fine from the ecu harness to the vtec sol. any ideas?
theres a chance i might go out to moreno valley today to pick up sum parts...if walnut is close by, i got an extra pr3 u can use to test ...have u tried grounding the pressure switch to the chassis?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">theres a chance i might go out to moreno valley today to pick up sum parts...if walnut is close by, i got an extra pr3 u can use to test ...have u tried grounding the pressure switch to the chassis?</TD></TR></TABLE>
how funny, i was in mo val today haha day street furniture row.
what does grounding the pressure switch do? i put a new one.
i found one wire last night going to the injector resistor, it got sheered between the nitrous plumbing and the strut tower bar. i fixed that, now when i hit 5k rpm, the car keeps driving like normal, no vtec, but doesnt bog nasty anymore.
but now i have cel, and its code 6, i checked the coolant switch on the block and on the head, they both work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold EF »</TD></TR><TR><TD CLASS="quote">humm
hard to find that computer, know anyone with one? in so cal area
I live in the so cal area. running a pr3 here.
</TD></TR></TABLE>I live in the so cal area. running a pr3 here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold EF »</TD></TR><TR><TD CLASS="quote">anyone with a obd 0 b16a ecu i can plug in my car?
::raises hand::
</TD></TR></TABLE>::raises hand::
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virginia_dude »</TD></TR><TR><TD CLASS="quote">If the ECU swap roves fruitless...consider the Vtec solenoid...I have heard of them failing at times.</TD></TR></TABLE>
in the first post i wrote that i tried that, but thanks anyways
CivicEJ041412
May 27, 2012 07:51 AM
Omegax10
25
Jan 13, 2012 08:05 AM
Firestarter
May 4, 2006 05:35 PM
