Would this pass smog??
Old Feb 26, 2002 | 12:25 PM
bhcvc's Avatar
Default Would this pass smog??
I'm wondering if this setup would pass the sniffer test. I'm deciding between a newer USDM B18C1 motor to swap into an EK and register it to be legal, then do the stuff listed below. If the below passes, then I can just get a normal smog check. But if the stuff below won't pass the sniffer test anyways, I might as well save some money and get an older JDM B18C1 instead.
- B18C resleeved to 84.5mm
- 12:1CR
- P&P head
- Jun Stage3 or Skunk Stage2 cams
Thanks.
Old Feb 26, 2002 | 12:28 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: Would this pass smog?? (bhcvc)
nope (again)
Old Feb 26, 2002 | 12:34 PM
bhcvc's Avatar
Default Re: Would this pass smog?? (vtecvoodoo)
Thanks Ryan. I wasn't sure the first time whether you meant it wouldn't pass visual or it wouldn't pass sniffer cuz other ppl were mentioning the data that gets pulled up on the screen. So I clarified it with the "registering it" part. Thanks.
z0ngtoker
Dec 22, 2008 09:53 PM
B16b-EJ8
May 10, 2006 11:58 AM
PePpeRedDc5
May 4, 2005 08:01 PM
00fbp
Nov 28, 2002 09:29 PM
