Carbon Fiber hood lifting?
has anyone else had this happen?: anytime i get past 70mph my hood will start to slighly lift up and down right at my wiper squirters. does this have anything to do with the rubber gasket thing that is supposed to go at the very front edge of my hood if so could i pop rivet it in? the plastic things that are supposed to hold it in are too big to go in there they just crumble up
yes sir it does...
my hood is modeled directly from oem so it latches the exact same and doesnt have any lift on the freeway, but everyone else i know that is using a c/f hood it lifts...
are you using hood pins?
Yes this happens all the time..did it crack your windsheld..Ive seen alot that do. Most companys recomend hood pins. Yes it for that reason. Get some and youll be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOstedEM1 »</TD></TR><TR><TD CLASS="quote">Yes this happens all the time..did it crack your windsheld..Ive seen alot that do. Most companys recomend hood pins. Yes it for that reason. Get some and youll be fine.</TD></TR></TABLE>
vis hoods have a warning label that says use hood pins.
its an oem seibon. i am not using hood pins and don't want to. it does have a underskeleton but it hasn't flipped up it is just lifting a little
I have some knock off carbon fiber hood that came with my car, but it fits and latches like oem... ive never had problems of it lifting or anything tho.
When Im up above like 60 or 70 mine lifts up and down a LOT, I mean I can sit up in my seat and look at it bounce up and down, it looks like the hood pins are the only thing holding it down even thought it latches too. Its just a cheap $350 one I bought a while ago. Its just all the air coming in the front and trying to escape, I thought it was normal for CF hoods, cause the stock metal ones are sturdier with the metal skeleton.
i think it is the gasket at the front edge of the hood i am going to try to put it on and see if that fixes it
yeadude i have that same problem with my fiber image hood that i haveon my ek...it sux, it makes me hella nervous b/c my friends gumballed home, holding 90 steady, watching my hood bounc up and down...got the W tho...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg9 »</TD></TR><TR><TD CLASS="quote">i think it is the gasket at the front edge of the hood i am going to try to put it on and see if that fixes it</TD></TR></TABLE>
PhatRoyale
27
Oct 8, 2009 08:20 AM
ShadyBAB
Nov 1, 2005 06:28 PM
