Probley a simple question for the gurus...... regarding 2 fuel fouled plugs.
#2 and# 4 have had gas on them each time i replace all 4 plugs which i have done 2 or 3 times the last 6 weeks the car hs been breaking up randomly through the 2-8k at differnt times sometimes she runs perfect and shortley after she will start to miss. I think its the timing But i have heard a injector could be the problem as well. this is on a basically brand new car 20k on built engine and tranny. new pump new filter pretty much all new on a chipped p28. I am getting pretty tired of this since my funding is almost gone and she has been nickle and diming like a shitty girlfriend.
Any help appreciated!
thanks James
Modified by decent at 11:45 AM 9/5/2005
thanks James
Maybe your ignition wires are breaking up on those 2 cylinders?
You could always swap injectors and see if the plug fouling follows the suspect injectors.
I wouldnt think it would be a fuel pump or filter problem since that would affect all your injectors plugs.
pyro.....good point i will try that tomorrow, I dont think that was the problem either i just didnt want anyone to reply and say check this(pump or filter i have gotten that more than once on releated questions.)but appreciate the feed back
James
James
fit256nj
19
Feb 15, 2006 09:19 AM
civicracer1993
15
Mar 20, 2003 08:29 PM
