EP3 Shift knob on 2004 ex
Old Sep 5, 2005 | 06:50 AM
wako182774's Avatar
Default EP3 Shift **** on 2004 ex
The oem shift **** on the 2001-2005 civic si should be a direct fit for the 01-05 civic right? i have a 2004 civic ex. Also does anyone know what jdm shift boots would be a direct fit for a 2004 ex?
Old Sep 5, 2005 | 09:35 PM
wako182774's Avatar
Default Re: EP3 Shift **** on 2004 ex (wako182774)
bump
Old Sep 6, 2005 | 12:09 AM
JCiv03's Avatar
YES, it is a direct fit. The 2002+ Civic SI's **** clips in directly into the 01 Civic coupe and sedans. I speak from experience.
Old Sep 6, 2005 | 06:19 AM
wako182774's Avatar
thanks alot man. I will be buying one today.
Old Sep 8, 2005 | 10:30 AM
wako182774's Avatar
also, does anybody know a nice set of jdm shift boot that would fit an 04 ex manual with the si ****? i would also like it to be connected the ****, not hanging on the shifter rod like i have seen on some cars.
Old Sep 9, 2005 | 09:32 AM
bricks2k4civic's Avatar
when you get the JDM shift ****, get the clip too. There is a 2004 civic shift boot on http://www.redlinegoods.com that you can get in any color leather with any color stitching. I have one and they are pretty nice. zip lock the boot to the new clip and install it. It's not too hard.
Old Sep 9, 2005 | 05:01 PM
wako182774's Avatar
Default Re: (bricks2k4civic)
its not a jdm shift ****, its the oem shift **** off of the usdm si/ep3. Would it clip to any boot that i buy? and i didn't want to get a knock off boot unless i have too, i was wondering if a jdm ctr or itr boot would work.
Old Sep 9, 2005 | 08:43 PM
BlueIntegraBoy's Avatar
To reconfirm, the EP3 **** will screw onto the shifter and the clip clips into the collar of the shift boot. As for the JDM shift boot (red stitching) you will need to use a DC5R shift boot, but it does not come with a collar to clip into. Instead you can cut of the clip portion of the shift ****.
Old Sep 10, 2005 | 02:40 PM
wako182774's Avatar
Default Re: EP3 Shift **** on 2004 ex (BlueIntegraBoy)
http://cgi.ebay.com/ebaymotors...ZWD1V
would that be able to fit? would it be able to clip onto an ep3 shift ****?
Old Sep 11, 2005 | 02:23 PM
wako182774's Avatar
bump
Old Sep 12, 2005 | 12:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wako182774 &raquo;</TD></TR><TR><TD CLASS="quote">http://cgi.ebay.com/ebaymotors...ZWD1V
would that be able to fit? would it be able to clip onto an ep3 shift ****?</TD></TR></TABLE>
Nope, there's no clip collar.
Old Sep 13, 2005 | 01:36 PM
wako182774's Avatar
would it not be able to clip into that pastic ring at the top to stay up to the ****?
Old Sep 13, 2005 | 01:39 PM
wako182774's Avatar
what about this one...
http://cgi.ebay.com/ebaymotors...ZWDVW
It has the plastic ring at the top. Is that what the clips on the bottom of the **** connect to in order to have to boot stay up?
Old Sep 13, 2005 | 02:04 PM
Here is a link to the insall.
http://www.redlinegoods.com/Civic04install.shtm
You just need to lock-tie the plastic part to the boot. If you want a new boot, I recomend redlinegoods.com shift boots - they are real leather and made to factory spec.
Old Sep 14, 2005 | 06:08 AM
wako182774's Avatar
thanks man, so this would also work with the ctr boots that i posted earlier from ebay?
flower5366
Honda Civic (2006 - 2015)
Feb 23, 2014 09:46 AM
Revolver123
Honda Civic (2001 - 2005)
Jul 21, 2008 06:55 PM
Minorgliche
Aug 11, 2001 09:02 AM
