Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
advice on cleaning/flushing fuel/gas tank (out of car)
Old Sep 5, 2005 | 06:36 AM
Lyonel 13H4's Avatar
Default advice on cleaning/flushing fuel/gas tank (out of car)
Hey guys- did a search, but still uncertain.
The donor car we bought for new car had been sitting for a really long time (wellover 1 year w/ gas in tank) in someone's back yard.
Tank is out of car. Tank is drained ("nastiness" is the only description I can think of to describe what came out of the tank during this process). Tank has been sitting outside our garage for a few weeks.
We are getting ready to put tank back onto the car. We want to "flush it" first though.
What should we use?
Gas, mineral spirits, etc etc?
Know this is "basic" but want to make sure we don't make a "stupid" mistake here....want to go racing asap!!
thanks!
Old Sep 5, 2005 | 06:44 AM
kedwards's Avatar
Take it to a radiator shop to get it flushed/tanked.
Old Sep 5, 2005 | 06:47 AM
Default Re: (kedwards)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kedwards &raquo;</TD></TR><TR><TD CLASS="quote">Take it to a radiator shop to get it flushed/tanked.
oh...so it isn't something we can do ourselves then? guess thats why we couldn't find a diy thread on the subject when searching....
Old Sep 5, 2005 | 06:49 AM
.RJ's Avatar
.RJ
Default Re: (Lyonel 13H4)
what did you do with the old gas?
Old Sep 5, 2005 | 06:50 AM
Default Re: (.RJ)
the "old gas" is still sitting in an old fuel jug in the garage...we aren't quite sure what to do with it....
Old Sep 5, 2005 | 07:18 AM
thawley's Avatar
Eastwood has a few products for this:
http://eastwood.com/shopping/p...+tank
http://eastwood.com/shopping/s...+tank
Old Sep 5, 2005 | 07:20 AM
smokin rubber's Avatar
I have seen the gas out of some old tanks, looks almost like varnish or urethane.
You could keep running fresh gas through it and your pump until it smells and looks like gas, or do what Keith said and have it flushed.
Old Sep 5, 2005 | 07:27 AM
Todd Reid's Avatar
Default Re: (smokin rubber)
hi guys!
glad to see you are almost back racing again!
i seem to recall some old timers telling me that you can fill the tank with a few handfuls of ball bearings, then put a couple gallons of gas in it, and shake it all around vigorously. the action of the ball bearings in the tank combined with the gas will remove the rest of the crap.
then drain out all the crap gas and ball bearings; put another gal of gas in, swirl around, then drain that out; should look clean and ready to go!
todd
ps i have not done this. just heard about it!
Old Sep 5, 2005 | 07:39 AM
Default Re: (Todd Reid)
thanks everyone...
(Danielle here) I was wrong...the old gas has been slowly used over a few months- in our Honda lawnmower.... being that Lyonel hasn't destroyed the lawnmower by using it (which was probably his hope as he has been trying to convince me to let him have a riding mower)...maybe it will be fine to just flush it with gas (& we'll try the ball bearing thing if we have some)...
Lyon is chomping at the bit to get lots done today & I'm certain we'd have a problem finding a shop open for him to get it professionally flushed today.... on the bright side there wasn't much gas in the tank when we drained/dropped it.
He was about to pour mineral spirits in the tank...thats when I freaked out & came to do a search...then this post.... just b/c that method worked on farm equipment "back in the day" (he hasn't been a farm boy for 15 yrs) doesn't mean it is a good idea on the Honda.... I've not find anything on mineral spirits being good or bad idea on our cars.... so thought I'd ask(hence the thread)
Old Sep 5, 2005 | 11:31 AM
UltimX's Avatar
How did you drain your tank? Did you just remove the bolt in the tank? I am in the same situation and I need to flush my tank out and am going to put new gas in. I can't get tubing in the actual opening of the tank and try to sphyon out the gas... any other suggestions? I just don't want the car to leak after I remove the bolt from the bottem of the tank.
Old Sep 5, 2005 | 12:26 PM
Default Re: (UltimX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">How did you drain your tank? </TD></TR></TABLE>
smart way is to utilize fuel pump... we didn't do it that way though....we removed bolt (we have a pit in our garage though) & drained into container.
Old Sep 5, 2005 | 04:14 PM
UltimX's Avatar
have you filled it yet? did it leak? and did you also replace the washer? I need to do this today.
delante(ej1)
Apr 7, 2013 10:10 AM
jdmeg6118
15
Aug 27, 2008 07:35 PM
GSR in progress 96
Dec 2, 2007 09:20 AM
urafag
Jun 30, 2006 05:07 AM
litterbox
28
Nov 4, 2005 07:36 AM
