First welds ever. any pointers?
Old Sep 5, 2005 | 06:20 AM
Krnbk2's Avatar
Default First welds ever. any pointers?
Last night i just started using the welder at my buddies shop. Its a fairly large Hobart MIG welder. we had some scrap SS laying around and had SS wire so we hooked it up and went to town. The ones circled are my welds. What can I do to improve them?
Old Sep 5, 2005 | 09:06 AM
97Alex's Avatar
Your off to a great start!
1stt pic looks looks like you need to spread out the puddle to the bottom plate in order to fuse em together well. Looks like you tried to do this but need more penetration b/w both plates rather than just the top plate. Not bad for beginner. Just try to fill in right smack between the 2 plates and then some.
2nd pic: Same peice just upside down?
Try tack welding the 2 peices together FLUSH. Again, need to work on fusing them together more.
Overall opinion: Your friend setup the mig correct? Your doing good man, just need to tack ur work before you weld together i guess.
Old Sep 6, 2005 | 04:28 AM
Krnbk2's Avatar
Default Re: (97Alex)
yea i think if i had 2 pieces that were flat i would have been able to get better coverage. oh well, i'll take another stab at it again tonight
Old Sep 6, 2005 | 06:03 AM
blueoval557's Avatar
Default Re: (Krnbk2)
less wire speed, slower rate of travel, or more heat...try one of the three
Old Sep 9, 2005 | 06:46 PM
scootertribe's Avatar
Default Re: (Tfreestyle)
Get an auto darkening helmet! J/k.
Maybe slow it down a little, and make a weave pattern between the 2 pieces.
Old Sep 9, 2005 | 11:41 PM
dreww..'s Avatar
good start
Old Sep 11, 2005 | 04:45 PM
Krnbk2's Avatar
Default Re: (scootertribe)
i was actually using one of the better autodarkening helmets that miller makes.
Ill post some new pics when i actually have a chance to weld again. thanks for all the comments and suggestions!
jchrm80
Welding / Fabrication
13
Aug 20, 2009 11:13 AM
Flashmn
Apr 28, 2009 02:42 PM
ilsimsli
Jan 29, 2006 06:39 PM
ladius
Nov 20, 2005 09:41 PM
ITR.#1446
Feb 21, 2005 01:52 PM
