Sticking Central Locking??
Old Sep 5, 2005 | 05:55 AM
bireltm21's Avatar
Default Sticking Central Locking??
Hi all!
Having a few problems with my Integra Type R's central locking.
The central locking ( not sure which part is causing it) any ideas? is sticking when I sometimes lock or unlock the car. I.e. I will turn the key to unlock the car and instantly the drivers door ( the one I am opening) will open but the passenger door will either not open or there will be a delay of between 3seconds and 25 seconds.
This had been happening for a bit and was also picked up by the Toad alarm engineer who cant fit the system until it has been fixed!
Problem is when i took it to honda it was working perfectly (grrr)
It could be either the Main solenoid, passenger slave solenoid or the switching gear... bit of a guessing game.
Have any of you's experienced this problem? Please help!!
Thanks! Jeremy
Old Sep 5, 2005 | 09:02 AM
Shawn C's Avatar
In The Garage
my guess is that honda (or someone else) took off the door panel, and got the rod that unlocks the lock bunched up in the foam. remove the door panel, and re-check that everything can move freely
it's probably the passengerside, but check both for good measure
viper111
Jan 10, 2013 09:59 AM
phils2k
Honda S2000
Sep 30, 2004 05:33 PM
gsr98teg
Feb 4, 2004 06:09 PM
