Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Brake issue: master or booster?
Old Sep 5, 2005 | 04:25 AM
Andy Hollis's Avatar
Default Brake issue: master or booster?
I need a sanity check.
So in the course of my race car rebuilding (see https://honda-tech.com/zeropost...53944), I now have mushy brakes. The new car as purchased had mushy brakes, but my old race car did not. So we swapped over all four corners of the brake system including the SS lines from the old car to the new. And we bled them really well (ran a quart of fluid through it with a power bleeder). So the only remaining items are the master and the booster.
Additional symptom: With the car off, I initially get a hard pedal, but pushing it harder it very slowly goes down to the floor. Sounds like the master is slowly bypassing?
I've had masters go bad before but they would bypass more suddenly as you pushed harder (car off).
What is the collective expert wisdom here? Master?
What's the symptom as a booster wears or goes bad?
I suppose I could just swap them both but its more work...
--Andy
Old Sep 5, 2005 | 04:52 AM
Mohudsolo's Avatar
Default Re: Brake issue: master or booster? (Andy Hollis)
A slow drop to the floor sounds like master cylinder, as does the mushy pedal. A bad booster should give no, or little, boost and cause a very hard pedal, but not a dropping one.
Did you find what was causing the camber issue on the driver's side?
Old Sep 5, 2005 | 05:28 AM
jsi's Avatar
jsi
Yup, it's the MC. Also check for any leakage on the rear wheel-cylinders, another possible culprit for crappy pedal feel.
Old Sep 5, 2005 | 05:47 AM
Catch 22's Avatar
Default Re: Brake issue: master or booster? (jsi)
And the master will also generally show its leaking if the bottom area of the booster has all the paint peeled off of it.
Brake fluid + Paint = Rust.
If you put a new MC in it make sure you bench bleed the crap out of it first.
Old Sep 5, 2005 | 08:48 AM
Default Re: Brake issue: master or booster? (Mohudsolo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohudsolo &raquo;</TD></TR><TR><TD CLASS="quote">
I believe so. So the other thread. Looks like the new car also had a tweaked upright (not as bad as the bent car, though). I'll have another part either today or tomorrow to go on there.
--Andy
Old Sep 5, 2005 | 06:00 PM
Twas the master cylinder. All better now. Thx. --Andy
Old Sep 5, 2005 | 06:09 PM
SMSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andy Hollis &raquo;</TD></TR><TR><TD CLASS="quote">Twas the master cylinder. All better now. Thx. --Andy</TD></TR></TABLE>
Well what also happens is the brake fluid, from the leaking MC, gets into the brake booster and starts to eat up the diaphram, then you get a vaccum leak and poor brakes.
BTW, this usually happens at the worst time.
Old Sep 7, 2005 | 04:02 AM
Coomer
May 21, 2008 04:39 PM
Specail Ed
Mar 31, 2008 08:25 AM
atmdc
21
Apr 11, 2007 07:06 AM
Axle
Jul 11, 2006 08:37 PM
MrIllegalX
Aug 24, 2003 06:27 PM
