help me out identifiying some sensors
trying to put this obd-1 b18a in my 90 si hatch, i'm having a hard time figuring out what 2 of these sensors do????
i looked on the Carland acura web site and the oem manual and im still confused
what the hell does B do?
if its for coolant then what is (A) for
E and D are for oil some how ( d is for oil pressure)
i would appreciate any help
the sensor(E) on the back of the block beside the oil pressure sensor(d) is a secondary fan switch, its like when the oil gets to hot it turns the fan on. its not needed, but if your going to ref it then just hook up a plug and tape the wires into the harness, ive done this 3 times now. as for the first pic (a)coolant temp sensor for ecu (B)coolant temp fan switch(88-91 has it on the back of the block) (C) coolant temp sensor for cluster
wow thats alot of typing
hope this helps
-joseph
hope this helps
-joseph
kreatekustomz
Sep 30, 2009 11:50 AM
joedr
Nov 9, 2008 12:11 PM
jason DB8
Apr 29, 2008 04:56 AM
