how to tighten up the hand brake?
Old Feb 26, 2002 | 10:28 AM
citanest's Avatar
New User
Default how to tighten up the hand brake?
Hi, I removed the center console but don't know where I can adjust the cable to make it tighter. My hand brake can pull all the way up to 45 degrees to a complete stop. That's way too high. Is there a way?
thanks
Old Feb 26, 2002 | 10:33 AM
Bob#455's Avatar
Default Re: how to tighten up the hand brake? (citanest)
Yes...there is a small 10mm nut that is connected to a spring... You can't miss it once you take the armrest out.
Old Feb 26, 2002 | 01:04 PM
citanest's Avatar
New User
Default Re: how to tighten up the hand brake? (Bob#455)
Thanks,
How do you know you have adjusted it too tight and the brake pads have started touching the rotor?
Old Feb 27, 2002 | 01:25 AM
citanest's Avatar
New User
anyone?
Old Feb 27, 2002 | 01:39 AM
DutchITR1689's Avatar
The shop manual says: 6 - 10 "clicks".
So, just adjust it to 6 clicks......
Sometimes it's necessary to "reset" the self-adjusting mechanism. You do that by loosen the nut all the way and press the brakepedal several times. And then retighten the cable again to 6 - 10 "clicks".
Old Feb 27, 2002 | 01:44 AM
citanest's Avatar
New User
Default Re: how to tighten up the hand brake? (EuroITR1689)
thanks, I guess 6 clicks mean: after hearing 6 clicks, you can't pull it anymore.
Old Feb 27, 2002 | 01:48 AM
Well, to be more accurate: after 6 clicks you should be pulling the handle with 200 N of force without going to the next 'click'.....
brettnahmann
Feb 24, 2013 06:06 AM
DC206R
Jun 24, 2009 11:59 AM
t_mac
Jan 13, 2009 01:13 AM
BeesDA6
Jan 14, 2004 07:31 AM
Sassafrass
Mar 3, 2003 06:31 PM
