Calling all B18c 2 Ek/ej swappers!!!
Old Sep 4, 2005 | 04:20 PM
FuNkDrSpOt's Avatar
Default Calling all B18c 2 Ek/ej swappers!!!
Ok, so im getting royally confused. Im doing a jdm b18c swap into my ej8 and i want to make sure nothing goes wrong or i dont need anything extra. I know that most of the sensors can be pulled off of my D16y8. I keep hearing conflicting stories on what mounts i need but http://tech.hybridgarage.com/ sez that all my car needs is a 99 Si rear bracket. I plan on doing a del sol radiator swap so let me know if i need something else. keep in mind im trying to B.A.R. my car and trying to keep my A/C
What i have so far:
98 Gsr usdm ecu
obdII lower timing belt cover
obdII crank gear
99' Si rear mount bracket
what i know i need still:
ObdII intake mani
Del sol dual core radiator
Some people say i need a 96 Del Sol AC bracket (38930-P54-000) to use AC but i want to know what people who have actually done this swap know.
Ok, so tell me if i
1) need anything else or any other brackets
2) need that certain bracket to run A/C
Help!!!
Old Sep 4, 2005 | 09:55 PM
FuNkDrSpOt's Avatar
Default Re: Calling all B18c 2 Ek/ej swappers!!! (FuNkDrSpOt)
bump
Old Sep 5, 2005 | 04:42 AM
FuNkDrSpOt's Avatar
bumporz
Old Sep 5, 2005 | 05:01 AM
dawrenn's Avatar
I have a B18C1 swap in my EJ8. You do need to use the Del Sol A/C bracket. I dont know about the other parts.
Old Sep 5, 2005 | 05:23 AM
FuNkDrSpOt's Avatar
Default Re: Calling all B18c 2 Ek/ej swappers!!! (dawrenn)
pm'ed you about some more info, if you didnt get it i was asking how much the bracket costs, is your car BAR'ed and if you knew of anything you did have to replace?
Old Sep 5, 2005 | 06:08 AM
97civicdx's Avatar
You also need the 99-00 SI engine block side motor mount, the one that bolts to the soda can mount.
Old Sep 5, 2005 | 06:18 AM
FuNkDrSpOt's Avatar
Default Re: Calling all B18c 2 Ek/ej swappers!!! (97civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx &raquo;</TD></TR><TR><TD CLASS="quote">You also need the 99-00 SI engine block side motor mount, the one that bolts to the soda can mount.</TD></TR></TABLE>
do you mean the driver side mount? And are you speaking from experience or from what someone else told you?
Old Sep 5, 2005 | 07:19 AM
FuNkDrSpOt's Avatar
bump for a DEFINITE friggin' answer
Old Sep 5, 2005 | 08:26 AM
Tyler H's Avatar
You probably would have found more help in the Hybrid forum, but here's what you need:
Driver side mount bracket- 11910-P30-000
This piece bolts to the enine block below thee cam gears. Reuse the
civic studs in this bracket. Also reuse all other civic parts at this
mount location.
99 SI rear upper mount- 50827-S04-N10
Bolts directly to engine block. Use stock civic mount on chassis.
A/C comp. bracket- 38930-P54-000 (definitely P54, not P30)
Bolts to B series block and civic compressor. No need to discharge A/C
system during swap. Leave all A/C lines connected. Use stock civic stud
in side of A/C bracket. Also reuse STOCK CIVIC mount on chassis. Integ.
piece is similar, but you must use the civic piece.
Front tranny mount- use integ. piece on tranny. Again, use stock civic
mount on chassis (like A/C bracket).
Upper tranny mount- use all civic pieces.
That'll get the motor in the car. As far as BAR, I don't think you can BAR a JDM B18C. They'll be looking for the number after the C (1,5). Those referee guys are no dummies. They know their stuff. I BAR'd a GSR motor in my car back in 2001, but it was a USDM B18C1.
Tyler
Old Sep 5, 2005 | 03:44 PM
97civicdx's Avatar
read tylers answer coz its 100% correct. I said the block side mount if you didnt read it correctly, not the soda can body side mount
Old Sep 5, 2005 | 04:00 PM
93CX's Avatar
from what i've heard you cant bar JDM b16b or b18c ITR/CTR motors
Old Sep 5, 2005 | 05:38 PM
FuNkDrSpOt's Avatar
Default Re: Calling all B18c 2 Ek/ej swappers!!! (93CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX &raquo;</TD></TR><TR><TD CLASS="quote">from what i've heard you cant bar JDM b16b or b18c ITR/CTR motors</TD></TR></TABLE>
Well i can tell you guys that BAR'ing a JDM is entirely do-able. One of the FAQ was on BARing a JDM ITR. The shop that im going through has already BARed a 94 JDM b18c into a 93 hatch.
Ok i understand what i need now but as far as what i need to buy vs. what i already have. Is there any way to break it down like that?
Example:
What i have-
99 si rear bracket
D series mounts
JDM GS-R mounts
What i need-
Is that correct?
b18rich
Jun 20, 2017 02:58 AM
Rez93del
Apr 7, 2017 06:00 AM
xvietxkhmerxboix
Dec 3, 2005 01:03 PM
FuNkDrSpOt
Sep 14, 2005 07:30 PM
kboy82
Jun 23, 2005 10:12 AM
