vtec problems
Old Sep 4, 2005 | 01:02 PM
jdm123's Avatar
Default vtec problems
i just did a gsr swap in my ek and i'm throwing the crank position sensor and the secondary 02 sensor. but whenever i hit vtec it will fall out and then fall back into vtec. my speedo goes all over the place as well as my tach. it just gets very crazy in vtec. what could this be from? thanks for the help
Old Sep 4, 2005 | 01:15 PM
postman's Avatar
Default Re: vtec problems (jdm123)
is this obd1 or obd2 motor,also what ecu
Old Sep 4, 2005 | 01:54 PM
jdm123's Avatar
Default Re: vtec problems (postman)
96 gsr motor. and its just a gsr ecu. p72
Old Sep 5, 2005 | 07:27 PM
jdm123's Avatar
bump
Old Sep 5, 2005 | 11:06 PM
Spoon*EK9's Avatar
hmmm....this sounds similar to a problem that I had on my Type R and my friend had/has on his EK.
On my R, it turned out that the Speedo sensor was shooting a code, but didn't know it until I had the car smogged. I changed the sensor out, and fixed it temporarily, but the problem kept coming back. Never had it fixed. I just got a OBD1 chipped P72 ecu so VTEC would still work. I didn't care about the speedo working at the time. I was told by someone that the wiring somewhere leading up to the sensor was bad and would cause a good sensor to pretty much go bad as soon as it was installed. Sounds crazy, but I never looked into it any further
My friend's EK has a JDM B18C SiR-G swap and I noticed that it has done this for the last month now. The speedo will occasionally twitch around and may stagger a bit when engaging in VTEC. He never gets a check engine light because his only happens for a moment. I noticed with my car that it got progressively worse. I'd like to know how many other people have this problem. I'd like to find a way to fix it. It's really annoying. I'm sure it is for you, too.
Old Sep 6, 2005 | 02:08 PM
jdm123's Avatar
Default Re: vtec problems (209SpoonEK9)
vtec still engages but now it is happening in the lower rpm's also. it's almost like its gonna puke out but then it keeps putting along. could this be a fuel problem?
Old Sep 7, 2005 | 02:27 PM
jdm123's Avatar
bump
chrisquin23
Jul 19, 2010 08:44 PM
toxicsynergy
Engine Management and Tuning
Jul 9, 2008 08:02 AM
melikeyjdm
Jan 10, 2008 08:21 PM
jdm123
Sep 6, 2005 08:27 PM
psycho_civic
Oct 23, 2003 08:33 AM
