do i neesd extended studs?
Old Sep 4, 2005 | 12:38 PM
helpthenoob's Avatar
Default do i need extended studs?
Well i have an eg hatch. I'm getting gt3's (i like them idc if you do). Do I need extended studs? Also is it stupid to put extended lug nuts on regular studs? (i got some for free) Thanks
Edit: I meant need in the title.
Old Sep 4, 2005 | 12:46 PM
japhonda's Avatar
Default Re: do i need extended studs? (helpthenoob)
i'm curious too. Since i'll be getting some soone.
Old Sep 4, 2005 | 01:00 PM
Old Sep 4, 2005 | 01:45 PM
japhonda's Avatar
h-t come on
Old Sep 4, 2005 | 02:09 PM
japhonda's Avatar
hello?
Old Sep 4, 2005 | 03:07 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helpthenoob &raquo;</TD></TR><TR><TD CLASS="quote">Well i have an eg hatch. I'm getting gt3's (i like them idc if you do). Do I need extended studs? Also is it stupid to put extended lug nuts on regular studs? (i got some for free) Thanks
Edit: I meant need in the title.</TD></TR></TABLE>Not sure if the GT3s will require them, maybe ask the manufacturer. Personally my EJ will be wide body with ARP extended wheel studs and wheel spacers for a wider track. But remember you usually have to run open-end lugs when using extended studs. Honda sells some of these but I forgot the PN off hand. Usually most parts stores will have or at least be able to get them for you. Sorry I couldn't be of any assistance on the question. Just my input though, the face of the wheel would have to be pretty thick or like I'm running wheel spacers, in order to require entended wheel studs..
Old Sep 4, 2005 | 03:23 PM
vsmhatched's Avatar
Default Re: do i need extended studs? (HondaFanatic708)
i dont think so, my friend has some GT3's on his EG. I like the way the look good rim choice
Old Sep 4, 2005 | 03:38 PM
belly-eg6's Avatar
naw u dont need them
Old Sep 4, 2005 | 04:28 PM
mike93eh
Guest
Posts: n/a
i have gt3s, no you dont need them. i personally think extended lugs are stupid.
Old Sep 4, 2005 | 05:44 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: (mike93eh)
you don't need them, make sure you get a good tapered lug nut, not the acorn one like OE
Old Sep 5, 2005 | 03:08 PM
What about extended lugs on normal studs?
Old Sep 5, 2005 | 03:18 PM
unknown0001's Avatar
Default Re: (helpthenoob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helpthenoob &raquo;</TD></TR><TR><TD CLASS="quote">What about extended lugs on normal studs?</TD></TR></TABLE>
that's what I have currently and there is no problem
Old Sep 5, 2005 | 05:26 PM
upgraded's Avatar
Default Re: (BrokeAssPinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">you don't need them, make sure you get a good tapered lug nut, not the acorn one like OE</TD></TR></TABLE>
Actually OE Honda lugnuts are a ball seat where as most aftermarket wheels take an conical seat or "acorn" lugnut.
Old Sep 5, 2005 | 05:36 PM
fwdtamiya's Avatar
Shouldn't you be more concerned with your dead friend?
JSA
Honda Civic (2006 - 2015)
Apr 7, 2011 02:05 AM
dc24me
Dec 7, 2007 11:21 PM
Jonathan_ED3
Apr 17, 2005 12:56 PM
Vp Special K
Nov 22, 2004 05:39 PM
