car won't start thread 5 zillion and 3
Old Sep 4, 2005 | 11:19 AM
VWVORTEX's Avatar
Default car won't start thread 5 zillion and 3
91 ef, stock.. car just turns and turns but doesn't fire, how do i test for spark.. also if my battery was dead wouldn't it click after a while and no headlights...
veriablo numero 2... the alternator belt was loose, maybe not charing the system,..
any help would be mucho awesomo
Old Sep 4, 2005 | 11:32 AM
InJ3cted's Avatar
Default Re: car won't start thread 5 zillion and 3 (GripStar)
take the spark plug out and put the wire on and hold it to a wrench or something and have a friend crank the motor over u should see spark if your getting any. since motor turns over then batt has enough power to turn the starter. Tighten your belt anyways. Are you sure your fuel pump is priming?
Old Sep 4, 2005 | 11:57 AM
VWVORTEX's Avatar
Default Re: car won't start thread 5 zillion and 3 (InJ3cted)
how can i tell if its the pump ?
Old Sep 4, 2005 | 12:33 PM
90h22acrx's Avatar
listen for the fuel pump when you turn your key on. it should humm for a few seconds. to test spark pull the plug out put it in the wire and hold the plug on a ground on your motor chasis etc. then turn the car over and you should se the spark. careful dont get your hand close to the plug.
evan221
Sep 6, 2014 12:31 AM
94hatchy
21
Nov 13, 2010 05:23 PM
streetjdmrex
Aug 8, 2007 12:59 AM
fwdftw
52
Sep 5, 2006 11:31 PM
johnjjy
Feb 24, 2006 11:20 AM
