gsr and b16 header interchangeable
ok my friend sold me a dc 4-1 header w/ 2" collector for 100$ it will be going in my 00si. an i dont know if the header is for a gsr or a b16...or are the interchangeable UNLIKE the intake manifolds. also if i decide to use this header my friends dad builds headers soo would it be worth it to bug him to make that a 2.5 inch collector?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingkong »</TD></TR><TR><TD CLASS="quote"> the only question left is whether it will reach or not reach your cat.</TD></TR></TABLE>
Ever consider deck height there genius?
all b-series headers fit b16b is a little longer at the collector. BUt i had the same header for 2 years on all my motors. b20 vtec, b16 , LS, and LS vtec they all fit just get a test pipe if the cat dont fit
Well, technically speaking, all B-series headers will bolt to all B-series heads (except for maybe that the bastard Prelude Si B20...), the problem is the B16 has a shorter deck height than the B18/B20, and B16B (which is really a B18C block with a B16 crank), so a B16 header doesn't usually clear the oil pan very well.
But in your case you are going the opposite way, and trying to put a long (B18) header on a B16, you will have extra clearance between the pan and header. Good for pan clearance, BAD for ground clearacance...
The 4-1 headers are bad for ground clearance already, and if you make it another ~10mm lower because of the B16, then you better hope your car is riding stock ride height...
Hope that helped some...
Also, I would prolly leave the collector at 2" unless you have some beefy mods to the B16, because going too big on the small motor is going to really drop your low and mid range torque, or lack thereof... if you are driving on the street/daily driver, I would keep it 2", drag/track car maybe go to 2.5"
A
A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCsideracing »</TD></TR><TR><TD CLASS="quote">Well, technically speaking, all B-series headers will bolt to all B-series heads (except for maybe that the bastard Prelude Si B20...)
i knew someone was gonna say that
M0nK3e.StyLeZ
15
Mar 30, 2005 07:04 PM
