Valve cover screw snapped. Need help!
I was painting my valve cover and when I was putting everything back in, one of the two top screws snapped. Now the end with the threads is stuck in the whole and I have no idea how to get it out. Will this affect the motor or anything? How can I get this fixed?
go to the hardware store
buy a new hard metal drill bit and an ez out
drill a hole in the snapped bolt, still in the head
use the ez out to remove the threaded section (they are reverse threaded)
Replace w/ a new bolt, tq only to 7-8ft/lbs
Since the ez out is reverse threaded, it will screw into the bolt and, at the same time, unscrew the bolt that you broke. Its easy
Oh, and dont drive your car to the store to get this. If you do, and dont have the bolt in, you're oil will probably spray out from under the loosely connected valve cover.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">go to the hardware store
Oh, and dont drive your car to the store to get this. If you do, and dont have the bolt in, you're oil will probably spray out from under the loosely connected valve cover.</TD></TR></TABLE>
not hard at all, I wouldnt even sweat it
All I can say is I know how you feel. TB pulley anchor bolt snapped on me when I rebuilt my Z6. I just said ****, tossed the DIY attitude away and went to a machine shop. Done in 10min and only cost me $20
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie »</TD></TR><TR><TD CLASS="quote">not hard at all, I wouldnt even sweat it </TD></TR></TABLE>
I'll give it a try.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond »</TD></TR><TR><TD CLASS="quote">All I can say is I know how you feel. TB pulley anchor bolt snapped on me when I rebuilt my Z6. I just said ****, tossed the DIY attitude away and went to a machine shop. Done in 10min and only cost me $20 .</TD></TR></TABLE>
Oh really?...
What to do now...
I'll give it a try.
Oh really?...
What to do now...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">its so easy , theres no reason to take the car to a machine shop</TD></TR></TABLE>
I'm was just worried because the screw that broke is realy small in diameter. Do you guys think that would be a problem? Can I use any small drill bit that will fit? Or is there something specific I should buy besides the ez out?
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">its so easy , theres no reason to take the car to a machine shop</TD></TR></TABLE>Yeah because if you were to take it to a shop you would have to either tow the car, remove the head. Patience is a virtue..
DIY will always save $ in the end.
Is my car really not drivable without that one screw holding the vc down? All the other 4 out of 5 screws are still intact.
Modified by 00ekcoupe at 10:55 PM 9/3/2005
your car is driveable
put some rtv gasket on the hole to cover it up
like i said b4
get a punch and slowly hit it at an angle to turn it lose until its out all the way
like i said b4
Exactly!!
Exactly!!
What do you mean by pilot hole? Have you gotten yours out yet?
Okay this is what I'm doing:
1. I tried to drill a small hole into the bolt with a small regular drill bit.
2. Now I use the easy out drill and drill it counter clockwise to get in? Then clockwise to get out?
Or vise versa?
Or vise versa?
small hole with regular bit = pilot hole.
what im going to do (havent found a drill yet) is drill the small hole like normal , then put the easy out in the drill , and counterclockwise start to back the broken bolt out. no need to screw it in as it might screw it in more.
It really wasn't that bad either. Now time to look for a new bolt.
