Wastgate and B.O.V. installation
Old Sep 3, 2005 | 06:50 PM
hondakevin21's Avatar
Default Wastgate and B.O.V. installation
Okay I decided to install a T3 turbo on my 1997 Honda Civic with a B16 and I have everything all setup except I am unsure as how it is i'm suppose to hookup the vacuum lines on both the wastegate and blow off valve. So if anybody could help me I would appreciate greatly.It's the only thing that has held me back from driving my civic for a while now.
Old Sep 3, 2005 | 07:20 PM
IMALLSLO's Avatar
Default Re: Wastgate and B.O.V. installation (hondakevin21)
Blow-off valve and wastegate both go to a manifold vacuum/port. If you have a dual vacuum wastegate like a turbonetics leave the top one to atmoshpere unless your adding a boost controller and the bottom to manifold. Blow off valve goes directly to vauum/port. Make sure if at all possible to run the vacuum lines to its own source vacuum for a more accurate reading. If you cant that'll be ok just think about a vauum box for the future purchase.
Old Sep 3, 2005 | 09:58 PM
Default Re: Wastgate and B.O.V. installation (IMALLSLO)
So should I just hook up both the b.o.v. and the wastegate to the brake booster line from the manifold or is there another source in which I could route it from, I'm just wondering because I have heard that doing this will effect my braking power. My civic is a DX hatch, and thanks for the help.
Old Sep 4, 2005 | 09:00 AM
veggiemaster's Avatar
Check this out.
https://honda-tech.com/zeropost...63795
dcintegra88
Jan 18, 2010 01:42 PM
95teilhatch
Sep 30, 2007 01:57 PM
draconx
Mar 15, 2006 06:03 AM
jdm-ray
May 15, 2005 09:37 PM
patdemps
May 16, 2004 10:06 AM
