H22a running rough, need help pinpointing...Measuring a voltage loss?
Old Sep 3, 2005 | 01:17 PM
crx4life2002's Avatar
Default H22a running rough, need help pinpointing...Measuring a voltage loss?
Well My problem with my h22a continues. The car is boosted and for some reason it is running like its on 3 cylinders but its not. I change dthe distributer and nothing changed, im also not getting any codes. My igntion is breaking up really bad at 5k+. So im thinking either and most likey electrical or fuel issue. Is there any way I can read a voltage loss? How do and were do I check if I am?
Old Sep 3, 2005 | 02:12 PM
antivic's Avatar
Default Re: H22a running rough, need help pinpointing...Measuring a voltage loss? (crx4life2002)
could be ur wires ...i had the same problem with my b16...spent 100+ in bs parts and it ended up being a sorta cut wire...
Old Sep 3, 2005 | 02:18 PM
Default Re: H22a running rough, need help pinpointing...Measuring a voltage loss? (antivic)
I took my wiring harness out couldnt find anything....is there a way to test the harness with a voltmeter?
Old Sep 3, 2005 | 04:18 PM
Goinfasterthanu's Avatar
i think he ment your plug wires...
Old Sep 3, 2005 | 05:16 PM
Default Re: (Goinfasterthanu)
brand new
Old Sep 3, 2005 | 06:19 PM
steveobb4's Avatar
Default Re: (crx4life2002)
Check the resistance of your plug wires, are you using colder plugs? Also you can check you engine harness for continuity for each wire , but you dont have any cel's so i dont know.
Old Sep 3, 2005 | 09:49 PM
Default Re: (steveobb4)
how do I check continuity and also resistance. How will I know if there is a problem and how do I fix it?Volts etc?
Old Sep 4, 2005 | 09:57 AM
Old Sep 4, 2005 | 03:49 PM
steveobb4's Avatar
You have a Dvom( Digital volt ohm meter) read your manual it will tell you the settings, if you think you have an open wire somewhere in your engine harness i would think you would have a cel. so check your ignition timing, it could be a simple ignition or fuel problem. Have you done a tune up at all, plugs ,check cap rotor, fuel filter. I cant really diagnose your car over the internet.
Old Sep 4, 2005 | 06:26 PM
HavokB18's Avatar
what wires do you have, because i had a BRAND NEW e set of neuspeed wires after 800 miles they went bad arching and ****... MSD's solved the prob. When in question on your wireing harness **** it rewire the bitch. Get another known good harness and start fresh.
georgen316
Oct 17, 2013 11:28 AM
colocho19
Dec 3, 2008 02:07 PM
ken2830
Jul 26, 2006 06:32 PM
delirious1520
Dec 23, 2005 08:00 PM
sicklude94
Sep 28, 2004 08:42 PM
