b18c5 block with b16 head ?? Some Questions ??
I'm putting a b18c5 block with b16 head in my obd1 car. I was wondering this......
Which Timing Belt do I use?
Which distributor?
Which intake manifold do I use?? b16 intake manifold alright?
What do I gap the spark plugs to? Type R or b16?
Which distributor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEGhasJDMfever »</TD></TR><TR><TD CLASS="quote">I'm putting a b18c5 block with b16 head in my obd1 car. I was wondering this......
Which distributor?
1 gsr/itr timing belt
2 obd1 vtec dizzy
3 b16/itr/skunk2/aebs/blox
4 gap to itr specs
5 good luck with your build.
Which distributor?
2 obd1 vtec dizzy
4 gap to itr specs
can someone please expand on the necesity of the obd1 dizzy?
i have a 2000 Si with obd1 conversion, going to fire it up after work - but i have the original obd2 dizzy. what kind of problems can i expect?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ( o )( o ) »</TD></TR><TR><TD CLASS="quote">can someone please expand on the necesity of the obd1 dizzy?
i have a 2000 Si with obd1 conversion, going to fire it up after work - but i have the original obd2 dizzy. what kind of problems can i expect?</TD></TR></TABLE>
when you say OBD1 conversion, you just mean the ecu harness correct? you have the OBD2 to OBD1 jumper harness to run like a P28? if this is what you have, then your OBD2 dizzy is good. hope that helps bro
showtymers619
Jun 4, 2004 10:23 PM
