B18B into 93 CX
Old Sep 3, 2005 | 11:39 AM
demitrix's Avatar
Default B18B into 93 CX
Ive read quite a bit on B swaps into 5g civics, but have failed on finding much info on swapping an LS into a 5g civic. Any info provided would be appreciated, parts lists,write ups, and the such.
Old Sep 3, 2005 | 12:32 PM
95dxhatch's Avatar
obviously you arent searching very hard.... its a plug and play swap just like all B series are. you'll need teggy mounts, p54 ac bracket if you wanna keep ac. youll wanna use either the obd1 LS ecu or a p06. anything else? its a straight forward swap like all b series are
Old Sep 3, 2005 | 08:03 PM
demitrix's Avatar
ok i had read that but i didnt if it was serisouly "plug and play"so i will need exlcluding a complete B series is teggy mounts and axles...
Old Sep 3, 2005 | 09:10 PM
hatchi's Avatar
Default Re: (demitrix)
you will need shift linkage from 94-00 integra, ecu
Old Sep 3, 2005 | 09:25 PM
RaYnE's Avatar
yeh, its straight forward.
you can actually use your civic mounts if you want, but if you do that, at least get new inserts. youll need the teg axles and shift linkage and ecu.
Old Sep 3, 2005 | 09:30 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: (RaYnE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaYnE &raquo;</TD></TR><TR><TD CLASS="quote">yeh, its straight forward.
</TD></TR></TABLE>You'll only need to replace the rear mount as far as this goes.. 94 DelSol VTEC or DC2 teg. The bracket not the actual mount on the subframe..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">you will need shift linkage from 94-00 integra, ecu </TD></TR></TABLE>
Pretty much plug and play as said, just make sure you have the right parts.
Old Sep 4, 2005 | 08:49 AM
RaYnE's Avatar
Default Re: (HondaFanatic708)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote">You'll only need to replace the rear mount as far as this goes.. 94 DelSol VTEC or DC2 teg. The bracket not the actual mount on the subframe..
thanks for the correction
Old Sep 4, 2005 | 11:24 AM
Jwbetley's Avatar
Default Re: (RaYnE)
cmon... the very top of this thread section.... "FAQ] What swaps are available for my Civic?"
Look in there
phaphon
Apr 5, 2010 03:22 AM
crxricer66
Nov 20, 2007 05:43 PM
slo_ej8
Apr 1, 2007 05:56 PM
2slowCivic
Sep 20, 2005 01:34 PM
Xgen
14
Jun 4, 2005 08:24 AM
