NGK Iridirum
Not worth it for Integras, their only benefit is extremely long life, which is good for cars where the plugs are very difficult to change. Just get some NGK copper plugs and change them every 10K-15K miles. It will still be cheaper in the long run.
i have the GReddy iridium plugs in my teg, i'm getting the car dyno'd tomorow so i'll stick the original bosch 4's in for the first run and then change them and see what gains if any there are, i'll let you know..
mugenracer, you will probably see gains because Hondas don't take the Bosch 4's very well from what I hear.
I ran Bosch Platinum plugs in my previous Honda ('86 CRX Si) and I was very pleased with the performance. The NGK and the Denso plugs run around $14 a plug whereas the standard Bosch Platinums run $2 a plug and the Bosch Platinum+4 run $6 a plug. So I'm kind of leaning towards the Bosch plugs (standard Platinum or Platinum+4).
I would welcome any feedback or information you may have.
NGK is the right kind
and as for Bosch 4's, the spark will travel between the shortest distance!
Also,
Since platinum has ~7 times more resistance than copper it's going to make power at 7 fold the amount of copper when amperage is applied, So the platinum will have to disipate that much more power in the form of heat and run hotter, no good for high compression, Theory only.
and as for Bosch 4's, the spark will travel between the shortest distance! Also,
they work good on integras, some dont recommend them if u have an aftermarket ignition such as msd., but most street racers use them in houston., iono, from my friends, they say its worth it
TravisCadello
14
Feb 4, 2009 11:41 AM
