took built b20-v to track the other day. not that happy.
Old Sep 2, 2005 | 06:33 PM
theinfamouskonrad's Avatar
Default took built b20-v to track the other day. not that happy.
well i took the crx to the track the other day. It has a basic hondata tune and is burning kinda rich. Setup is b20 block eagle rods, 12.5:1 je's. b16a head mild port polish, crower stage 3's, skunk manifold, greddy header, all the bolt on's etc. I ran a 14.2@100mph w/ 200+lb person in the car. couldn't get traction at all off the line here's the specs...
r/t .615 (i know i was sleeping)
60' 2.400
330 6.261
1/8 9.344
mph 80.41
1000 11.994
1/4 14.249 @100.77
next time i'm gonna try with slicks and get my hondata launch control working. I also have a traction bar i'm gonna throw on. anyone have any suggestions or dealt w/ hondata's launch control?
Old Sep 2, 2005 | 08:48 PM
Viorent Grip! EG's Avatar
Default Re: took built b20-v to track the other day. not that happy. (konrad)
well...ur mph's are decent....but your 60's are killing your times...
with some decent street tires...a 2.1 or 2.2 isnt out of the question..that'll drop your time alot right there...
if your going on slicks and are able to pull off a 1.6-1.7....you'll see some really good times...
how much power are you making???
and what tranny are you using?
Old Sep 2, 2005 | 09:25 PM
Default Re: took built b20-v to track the other day. not that happy. (Viorent Grip! EG)
looking at around 190-200whp tops as of now. It still needs more tuning. I'm using a cable b16 tranny Y1.
Old Sep 2, 2005 | 09:37 PM
xDicktonesx's Avatar
100 mph = mid 13s. i think your front bumper is holding you back. kidding.
190hp? what kind of torque?
Old Sep 2, 2005 | 09:43 PM
Default Re: took built b20-v to track the other day. not that happy. (CRXofPain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXofPain &raquo;</TD></TR><TR><TD CLASS="quote">100 mph = mid 13s. i think your front bumper is holding you back. kidding.
190hp? what kind of torque?</TD></TR></TABLE>
i'm not a fan of body kits at all either. Car was stolen and crashed so i went the easy way out
The hp ratings i gave are just a rough estimate. The car hasn't been dynoed at all so i can't give an exact # on torque. But you know how much torque the b20 puts out so it's a decent amount. If only i can stop peeling and wheel hopping
Old Sep 2, 2005 | 09:44 PM
RudeBwaiSi's Avatar
I don't see why you would be "not happy" with the time you ran. Cause your ET and 1/4 time shows you must have been slipping and not gripping. Get better tires and go, also if you have stock axles, watch them with the grippy tires.
Old Sep 2, 2005 | 09:48 PM
Default Re: (RudeBwaiSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeBwaiSi &raquo;</TD></TR><TR><TD CLASS="quote">I don't see why you would be "not happy" with the time you ran. Cause your ET and 1/4 time shows you must have been slipping and not gripping. Get better tires and go, also if you have stock axles, watch them with the grippy tires.</TD></TR></TABLE>
well i was hoping to hit high 13's at least with the setup. i do have stock axles so i'm gonna have to watch out. i'll be running it again next week hopefully to see what i can get out of it. Then the engine's going up for sale since i'm going all out with a k20
Old Sep 3, 2005 | 07:31 PM
Default Re: (konrad)
with some good traction..your trap speed is good for a 13 second pass....
as for your power.... i think that you should really get your set up tuned...esp since peak numbers are total BS without a good power curve.
might wnat to think about some other parts....
clutch...are you slipping?
lsd....
traction bars..i know you said you'll throw em on..but i heard they work wonders.
better tires....btw what tires were you on before?
suspension...what are you running??
are you on heavy *** wheels
personally, i think something is wrong somwhere besides your motor...
your making the power, your traps are proof of that...
Old Sep 3, 2005 | 10:21 PM
Default Re: (Viorent Grip! EG)
clutch...are you slipping?-not slipping. got a act streetdisc clutch(non-pucked)
lsd.... No lsd. Just a y1 b16 cable tranny
traction bars..i know you said you'll throw em on..but i heard they work wonders.-i have an avid traction bar that's been sitting here for a while...just didn't have a chance to put it on yet.
better tires....btw what tires were you on before?- i was using kuhmo tires on 17" black rims
suspension...what are you running??-tokico illumina's. neuspeed springs, complete energy suspension polyurethane bushings.
Old Sep 3, 2005 | 11:02 PM
rjay8604's Avatar
I know how you feel, don't feel too bad. For reference here are my also somewhat disappointing times. My setup= 91 hatch 2100 lbs + 203whp = 13.9@102 so as you can see i also seem to have less than stellar results. Keep this in mind, usually what the magazines get out of cars is never what anyone will get . I raced a stock 05 Sti, with a 2.0 60' he only managed a 14.5@95, a new stock retro mustang i lined up with only pulled a 14.1 w/ a 2.1 60'. So when you go see how other cars are doing so you can guage if its the track/conditions that are hurting you. I have noticed my local track seems everyone runs slower than normal, so i expect it.
Old Sep 4, 2005 | 07:51 AM
Grand's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by konrad &raquo;</TD></TR><TR><TD CLASS="quote">clutch...are you slipping?-not slipping. got a act streetdisc clutch(non-pucked)
since you have illuminas and they are adjustable try to soften them up to the max in the front and stifffen them in the rear put 15s on it and buy either drag radials or slicks then have your motor TUNED add that traction bar then go out and enjoy low 13s or even possible high 12s
Old Sep 4, 2005 | 07:59 AM
Rollo Lawson's Avatar
well, i can tell you that the Y1 gearing isn't helping you. take time to get those skills up.
Old Sep 4, 2005 | 10:40 AM
Default Re: (LG_R32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LG_R32 &raquo;</TD></TR><TR><TD CLASS="quote">since you have illuminas and they are adjustable try to soften them up to the max in the front and stifffen them in the rear put 15s on it and buy either drag radials or slicks then have your motor TUNED add that traction bar then go out and enjoy low 13s or even possible high 12s </TD></TR></TABLE>
on that run i had the illumina's stiffened to the max on the front and the back. I'll try it next time with softening them in the front. i'll get some vids up so u guys can check it out as well
Old Sep 4, 2005 | 12:27 PM
DIFFUT'S INC.'s Avatar
traction bars.. get full Race
better tires.... get some BFG Drag Radial
Old Sep 5, 2005 | 03:00 AM
Default Re: (DIFFUT'S INC.)
motors for sale? pm me.
Old Sep 5, 2005 | 09:07 AM
Suprdave's Avatar
Default Re: (CRXofPain)
You silly kids need to buy slicks...
Old Sep 5, 2005 | 09:08 AM
Supernatural's Avatar
Default Re: (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">You silly kids need to buy slicks...</TD></TR></TABLE>
Old Sep 5, 2005 | 10:58 AM
Junkiii Ek's Avatar
Default Re: (SUPERNATURAL)
Old Oct 29, 2005 | 02:01 PM
Default Re: (Junkiii EJ8)
update car ran a 13.496 @105.57 last week w/ better street tires + traction bar installed. Everything else the same setup.
r/t .609
60-2.153
330-5.853
1/8-8.801
mph-84.53
1000-11.346
1/4-13.496
mph-105.57
vid here. http://www.we-todd-did-racing....5NTQx
Old Oct 29, 2005 | 02:54 PM
SiR831's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by konrad &raquo;</TD></TR><TR><TD CLASS="quote">update car ran a 13.496 @105.57 last week w/ better street tires + traction bar installed. Everything else the same setup.
r/t .609
60-2.153
330-5.853
1/8-8.801
mph-84.53
1000-11.346
1/4-13.496
mph-105.57
wow, what an improvement from the other e.t. Noticed that your 60 went down. What tires are you running now?
Old Oct 29, 2005 | 03:21 PM
Default Re: (SiR831)
i'm running 15" rims w/ bf goodrich g-force tires.
Old Oct 29, 2005 | 04:47 PM
Grand's Avatar
r/t .609
60-2.153
330-5.853
1/8-8.801
mph-84.53
1000-11.346
1/4-13.496
mph-105.57
vid here. http://www.we-todd-did-racing....5NTQx </TD></TR></TABLE>
theres an improvment , are you happy now ? it will still get faster with more practice also try playing with your suspension aswell
Old Oct 29, 2005 | 04:52 PM
SIXTY's Avatar
You should definitely run slicks now. 60 foot time alone will put you close to a twelve .
Old Oct 29, 2005 | 05:33 PM
rjay8604's Avatar
Default Re: (b1886crx)
Dang, no fair. how you get all those extra mph? Good job i'm jealous. I need higher traps, but you are doing good now. You have the traps for 12's.
Old Oct 29, 2005 | 05:45 PM
Default Re: (rjay8604)
yea i'm gonna try and run it one more time this year after i fix a few things. I need to get it tuned right on the dyno and i'm going to try and borrow some slicks for the last run. any other advice guys let me know
Mhollaek9
Aug 11, 2007 08:57 PM
B18C1CYA
Jul 26, 2004 08:15 PM
g2turbo
May 20, 2003 05:18 AM
b19coupe
Feb 8, 2003 12:44 PM
hybrid901
Apr 10, 2002 02:58 PM
