People with the JDM 5 lug conversion on their GS-R
Help!!! People with the JDM 5 lug conversion. I'm installing the JDM 5 lug into my car but I ran into a problem. I noticed that the JDM cars don't use abs and my car has it. WHAT SHOULD I DO???? Please let me know what you did and how it is working for you... Thanks!
you would have to get a spindel that has the ABS stuff on it.
solution?
press out hub and bearings form the 5 lug setup,
press out hub and bearings from the gsr set
press new bearing and old 5lug hub into gsr spindel
if you have the ITR setup for the large axels then scratch that idea for the front
for the rear, simply unbolt the big *** nut in the back, and buy NEW bearings and put the 5 lug hub in the orginal trailing arm with the new bearings
solution?
So you are saying that if i get new bearings then i will be able to keep the ABS with the 5 lug conversion? What if i just want to completely remove the ABS system...how would i go about that?? thanks for any help.
I have been reading alot of searches that I found about ABS removal, but they all suggest that you should buy RS props and Brake lines. I dont know if this is true, but someone told me that I could simply clamp it off without replacing anything...IS this true? I am not looking forward to spend additional money if it is unnecessary. Someone please help me out.
i put on a ctr suspension and it had the places to put the abs..
have you tried to put it on... its just two bolts for the abs on each side
the holes were just really rusty/dirty hard to get in. but it worked... i got abs 5lug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_dc2 »</TD></TR><TR><TD CLASS="quote">Help!!! People with the JDM 5 lug conversion. I'm installing the JDM 5 lug into my car but I ran into a problem. I noticed that the JDM cars don't use abs and my car has it. WHAT SHOULD I DO???? Please let me know what you did and how it is working for you... Thanks!
I was in the same situation as you were with my 5-lug gsr conversion. Not all type r 5-lugs came equiped with ABS from japan so the machine stock on the casting was never milled down and taped with the mounting holes. Careful cause the tolerance is critical on the hieght of your ABS sensor. My girlfriend ended up driving the gsr ...soooooo whats left of my 5-lug conversion is collecting dust in the Garage
and if you insist i don't know what im talking about please have some pics to back up your statement, because i will (later in the evening)
</TD></TR></TABLE>I was in the same situation as you were with my 5-lug gsr conversion. Not all type r 5-lugs came equiped with ABS from japan so the machine stock on the casting was never milled down and taped with the mounting holes. Careful cause the tolerance is critical on the hieght of your ABS sensor. My girlfriend ended up driving the gsr ...soooooo whats left of my 5-lug conversion is collecting dust in the Garage
radicaled434
Aug 25, 2009 11:18 AM
