h22 swap-front motor mount.
Old Sep 1, 2005 | 06:59 PM
JDM H22's Avatar
Default h22 swap-front motor mount.
I have a JDM H22 in my 93 Accord, and there are only 2 bolts on the front mount mounting to the engine. There is a 3rd hole but It doesnt mount up right. I know you need to modify this but will there be any negitive side effects running just the 2 bolts? The engines already in the car so taping a hole would be kinda difficult. Should I run it or find another solution? Thanks
Old Sep 1, 2005 | 07:21 PM
v4lu3s's Avatar
RTFM
my swap was originally donew ith 2 bolts on teh front mount bracket.
i now have a block with broken off bolts in the holes and a broken front mount bracket.
Old Sep 2, 2005 | 06:09 AM
jin05's Avatar
Default Re: h22 swap-front motor mount. (JDM H22)
the h22 motor is made to drop in straight without any mods for a 94 to 97 accord, any year below that needs a little mods on the chassis in order to drop in the motor
Old Sep 2, 2005 | 06:33 AM
ROCsFinest's Avatar
^^^^ i thought it was the other way around...
Old Sep 2, 2005 | 09:04 AM
turboH22Aakkord's Avatar
Default Re: (ROCsFinest)
i did a swap on my 92 accord and i didnt have to touch any of the mounts... and as far as the front motor mount goes... some guys dont even use it... i used mine and it bolted right up. ( the 3" down pipe from the turbo made stuff pritty close though)
Old Oct 8, 2005 | 07:18 PM
JDM H22's Avatar
Default Re: (turboH22Aakkord)
You know people who are running with out the front mount!!?? Is that safe?
Old Oct 8, 2005 | 08:12 PM
v4lu3s's Avatar
RTFM
i ran with no front mount for over a year, but i did have a rear mount insert.
Old Oct 8, 2005 | 08:31 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: h22 swap-front motor mount. (jin05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jin05 &raquo;</TD></TR><TR><TD CLASS="quote">the h22 motor is made to drop in straight without any mods for a 94 to 97 accord, any year below that needs a little mods on the chassis in order to drop in the motor</TD></TR></TABLE>
Wrong. Take of your dog bone bracket from your F22 and put it on your H22 then you can use your dog bone mount. By the way the front and rear mounts are the most important mounts as they control (or contain) the torque of the motor.
Old Oct 8, 2005 | 08:37 PM
v4lu3s's Avatar
RTFM
what dogbone mount is on the 94-97 accord? iu have never seen one that looks anything liek the 90-93 dogbone....
Old Oct 9, 2005 | 08:03 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (v4lu3s)
The poster said he has a 93 Accord. Thats who the info is for. As for jin I only stated he was wrong.. 2 seperate responses,my bad.
Speedfiend97LX
May 4, 2011 09:06 PM
Pre_4_Me
Mar 4, 2009 11:18 PM
H22CL
Sep 29, 2004 09:51 AM
OutlawCL
Sep 11, 2004 01:20 PM
