Fully built LS/VTEC
Im done with my LS/VTEC setup.. I wanted to try out all motor for a while so this is what i came out with......
96 B18b1 Motor
Oversized Civic Type R Pistons
Stock GSR Rods
ARP Rod Bolts
All New GSR honda bearings
Fully balanced GSR Crank with CTR N1 Pully
GSR Girdle, Oil Pan, Oil Pickup
Blueprinted Block
B16a2 Head
Crower Stage 3 Camshafts(ITR SPEC)
Crower Valves, Springs, Retainers(ITR SPEC)
Skunk 2 Intake manifold(port matched)
Ported and Polished head
JDM ITR 4-1 header
2.25" Exhaust
ES oval Muffler
Cable B16a Transmission
6 Puck ACT Clutch
8.5lb Flywheel
Apexi VAFC
450cc DSM injectors
VTEC X overs is 5400rpm
Breaking in the motor and it feels so rev happy... will takes pics when i get home from work.... I plan on taking this motor to about 8500rpm do you guys see a problem?
96 B18b1 Motor
Stock GSR Rods
ARP Rod Bolts
Blueprinted Block
B16a2 Head
JDM ITR 4-1 header
2.25" Exhaust
ES oval Muffler
6 Puck ACT Clutch
8.5lb Flywheel
Apexi VAFC
450cc DSM injectors
i like the setup, the CTR pistons will raise the compression, but the GSR rods and crank will lower it a bit. I know with that kind of bottom end work and head work, as long as you have good tuning you should be able to take it to 9K+! My only real advice is that if you can afford it..... buy an Ostrich fuel management setup and tune it with that and a laptop, instead of a VAFC. I'd consider myself an awesome tuner with the AFC but you can't change timing maps with it. Ostrich setup is only $200.00
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Novtecdohc »</TD></TR><TR><TD CLASS="quote">Im done with my LS/VTEC setup.. I wanted to try out all motor for a while so this is what i came out with......
96 B18b1 Motor
Stock GSR Rods
ARP Rod Bolts
Blueprinted Block
B16a2 Head
JDM ITR 4-1 header
2.25" Exhaust
ES oval Muffler
6 Puck ACT Clutch
8.5lb Flywheel
Apexi VAFC
450cc DSM injectors
Am I missing something, I'm sorry if I'm oblivious, but....
So how exactly does this make an "LS" Vtec without LS Rods and Crank?
96 B18b1 Motor
Stock GSR Rods
ARP Rod Bolts
Blueprinted Block
B16a2 Head
JDM ITR 4-1 header
2.25" Exhaust
ES oval Muffler
6 Puck ACT Clutch
8.5lb Flywheel
Apexi VAFC
450cc DSM injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rughead »</TD></TR><TR><TD CLASS="quote">need better rods </TD></TR></TABLE>
Please explain to me why he needs better rods. Look at the motor in my sig. It is over 240whp and I have stock Type R rods. Nothing wrong with his rods. They handle over 300whp in stock short block turbo charged configuration. Don't just state things for the sake of stating them. YOUR rods will be more than adequate for this application.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sik civic »</TD></TR><TR><TD CLASS="quote">Am I missing something, I'm sorry if I'm oblivious, but....
So how exactly does this make an "LS" Vtec without LS Rods and Crank?</TD></TR></TABLE>
So if you put an 89mm crank in a GSR block do you call it an LS???? Or if I put a 95mm Crank in my B18C is it no longer a B18C. You always predicate the motor off of what the engine code says. It is an LS block therefore he has to run an external oil line to the head for VTEC operation therefore it is an LS-VTEC motor. This place is making me cranky lately.
915hondajunkee
Nov 26, 2008 07:23 AM
fliptout
Jul 7, 2006 10:33 PM
