plx install having cel prob
Old Sep 1, 2005 | 03:58 PM
5thGenFanatic's Avatar
Default plx install having cel prob
hi i just installed the plx air/fuel monitor... the 300... iin my 4 door civic with b swap... ran power and ground, installed the sensor and wired the narrowband gray wire to d14... my check engine light keeps coming on does anyone know the color wire of d14 so i can make sure i got the right one..or has anyone had this happen before?
Old Nov 3, 2005 | 04:08 PM
dpetro1's Avatar
Default Re: plx install having cel prob (5thGenFanatic)
you are probably getting a code for the o2 heater. you will probably need to wire in the resistor to get rid of it unless you are using an EMS that can disable the heater
Old Nov 18, 2005 | 09:32 PM
streetrays's Avatar
yeah, that seems to be the more common problem.. 'cheater' resistor may be needed for the heater wire..
5thGenFanatic
Sep 4, 2005 08:06 AM
5thGenFanatic
Sep 2, 2005 06:14 AM
5thGenFanatic
Sep 1, 2005 07:19 PM
5thGenFanatic
Sep 1, 2005 04:24 PM
SuperDuude
Jul 17, 2004 04:25 PM
