Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Hawk HPS Brake Pads swishing and squealing
Old Sep 1, 2005 | 06:54 AM
Dogginator's Avatar
Daisy... Daisy...
Default Hawk HPS Brake Pads swishing and squealing
I just put a set of Hawk HPS brake pads on my '97 Integra. These were installed simultaneously with new Brembo blank rotors and new Accord V6 calipers. (These are essentially the same brakes as the ITR. The details are here.
I have bedded these pads using the StopTech method for street performance pads. The problem that I am having is that the front brakes are making a swishing sound as I drive. (This sound is constant, not periodic.) It seems like the pads are lightly touching the rotors. Of course, the rotors still have that new, record-groove appearance. Is this a normal occurance?
The pads also squeal slightly after brake release, but I am not as concerned about that.
Old Sep 1, 2005 | 07:44 AM
prkiller's Avatar
Default Re: Hawk HPS Brake Pads swishing and squealing (Dogginator)
From what your describing, it sounds normal to me. I would just check and make sure nothing is causing an interference with each other. IE rotor rubbing on caliper.
Old Sep 1, 2005 | 07:53 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Hawk HPS Brake Pads swishing and squealing (prkiller)
Thanks for the reply. I wasn't sure what exactly Hawk meant by "low noise". My calipers were machined to have the proper offset with those rotors and the splash guards were removed.
The brakes feel fine, and there isn't any noticeable drag when coasting.
Will this swishing subside as the rotors wear a bit, i.e. the record grooves are removed?
Old Sep 1, 2005 | 07:56 AM
fireant's Avatar
My HPS's started to make some noise at creeping speed. I took the pads out, used compressed air on everything, then put em back on. Seems to have made the noise go away.
Old Sep 1, 2005 | 09:42 AM
00R101's Avatar
Default Re: Hawk HPS Brake Pads swishing and squealing (fireant)
Swishing and squealing??? Did you buy the gay or straight pads?
Old Sep 1, 2005 | 09:51 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Hawk HPS Brake Pads swishing and squealing (00R101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00R101 &raquo;</TD></TR><TR><TD CLASS="quote">Swishing and squealing??? Did you buy the gay or straight pads?</TD></TR></TABLE>
You mean they don't normally come in a fuchsia box with iridescent accents?
Old Sep 1, 2005 | 10:24 AM
Crazydave's Avatar
You mean you don't like your girlfriend knowing that you have mAd tIgHt bRaKes Yo!
Old Sep 1, 2005 | 01:59 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">My HPS's started to make some noise at creeping speed. I took the pads out, used compressed air on everything, then put em back on. Seems to have made the noise go away.</TD></TR></TABLE>
Was your noise a squeal or a swish?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">You mean you don't like your girlfriend knowing that you have mAd tIgHt bRaKes Yo!</TD></TR></TABLE>
Just don't let my wife know.
Old Sep 1, 2005 | 02:59 PM
Crazydave's Avatar
swish,..
are you able to freely turn the rotors by hand, or does it have resistance?
the squeling you may have to deal with, or try installing shims.
Old Sep 1, 2005 | 03:19 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Hawk HPS Brake Pads swishing and squealing (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">swish,..
the squeling you may have to deal with, or try installing shims.</TD></TR></TABLE>
There is no mechanical interference, as the rotors turn freely by hand when the wheels are mounted. I personally think that it is a combination of the asperities on the new pads and the new rotors that are lightly contacting and making the swishing sound. I just have no experience with these particular pads and need to know if this characteristic is normal.
The squeal is minor and typically only occurs after releasing the brakes and slowly rolling. Some caliper grease on the pad shims will most likely address that issue.
Old Sep 1, 2005 | 09:09 PM
Circuit Star-29's Avatar
Mine also make this sound. Normal. Just wait till you see their "Low dust (yeah, right)" pad in action...Good stopping power once you get on it.
But unless you have ABS, you'll need to be very careful when you get into slower speeds...they'll lock up pretty easily.
Nice upgrade.
a.wax
Sep 15, 2007 06:53 PM
lenjai
Suspension & Brakes
Aug 16, 2006 02:11 PM
faSHOwidIT
Apr 18, 2005 02:06 AM
B18CYAAA
Oct 1, 2003 08:18 PM
timbuktu
Mar 22, 2002 12:50 PM
