the fast idle valve
Old Aug 31, 2005 | 09:46 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default the fast idle valve
the fast idle valve
does that plug into the DPFI tandum control wires and not messed with at ECU?
just cut the tandom plug off and solder on fast idle plug? or do i even need it for MPFI swap?
Old Aug 31, 2005 | 09:49 PM
DocSean's Avatar
You don't NEED a FITV valve period; however, by removing it you will need to plug some coolant lines and you won't get that "high idle when you start your car in the cold" thing. I'm not familiar with the DPFI, but I recently removed mine on my b-series swap.
Old Aug 31, 2005 | 10:00 PM
DieMaster's Avatar
Default Re: (spankjelly)
is this what your talking about?
b/c thats not it. it's on the backof the intake mani near #1 port and has a blue and blk/yel wire on it
Old Aug 31, 2005 | 10:11 PM
DocSean's Avatar
Default Re: (DieMaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster &raquo;</TD></TR><TR><TD CLASS="quote">is this what your talking about?
b/c thats not it. it's on the backof the intake mani near #1 port and has a blue and blk/yel wire on it </TD></TR></TABLE>
The part that has the black box around it is the FITV or fast idle thermo valve...it has a hose running to it from the thermostat.
Old Sep 1, 2005 | 10:54 AM
DieMaster's Avatar
Old Sep 1, 2005 | 11:15 AM
DocSean's Avatar
Ok...the part highlighted in the picture is the FITV....the part on the BACK of the manifold which is NOT pictured is called the IACV and is necessary...but again, I'm not familiar with your conversion, but you WILL throw a code without it.
Old Sep 1, 2005 | 12:24 PM
DieMaster's Avatar
sigh not the idle control motor. it's right next to it
Old Sep 1, 2005 | 12:39 PM
DocSean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster &raquo;</TD></TR><TR><TD CLASS="quote">sigh not the idle control motor. it's right next to it </TD></TR></TABLE>
Haha...you feel like the guy in your avatar?
Sorry I can't help anymore man, I just completely ripped my mani out and the ONLY thing I had to keep that was actually attatched was the IACV. Hopefully someone else can chime in here and give you a hand.
njkill
Jul 24, 2010 06:25 AM
MAYHEM
Feb 20, 2005 07:20 PM
s2k
Feb 25, 2003 06:50 PM
maximedx
Apr 5, 2002 07:22 AM
Accorden
Mar 30, 2002 08:03 PM
