h22 in an ek
Old Aug 31, 2005 | 08:40 PM
RacingShoeBox's Avatar
Default h22 in an ek
how well would a h22 motor fit in a ek coupe i herd they are a little bigger so i gotta loose the ac and what not... just getting it out now i dont know much of anything about h22 motors so be nice lol
Old Aug 31, 2005 | 10:16 PM
cant find what i need im wonderen if anyone did a h22 in a civic coupe ek with their pros and cons
Old Aug 31, 2005 | 11:39 PM
vroomvroomcivic's Avatar
well there are kits that make you keep a/c as well as p/s pros and cons, can't really help you there, but what are you looking to get out of the h22 if you swap it in?
Old Sep 1, 2005 | 12:42 AM
BoOstedEM1's Avatar
Default Re: (JDMChrisEK)
I did an h22 into ek..Distributor had me confused for a sec..but there is write up everywhere for that. Its been done a million times..
Old Sep 1, 2005 | 07:20 AM
nice well im really only lookin 2 do low 13s on street tires and then use it as a mild daily driver
Old Sep 4, 2005 | 12:27 PM
hwH22hx's Avatar
HI in response to the H22 swap in the EK....
I am currently swaping an H22 into my HX ( it was also an auto to manual conversion ) this swap is definitely not cheap [....especially for this model civic ) the swap is still currently underway. There have been some complications with the engine mounts the passenger side sub-frame needed to be replaced w/ one from a 5 speed. The complications go one....but never deterred me to not go all the way.
Obviously, you won't be keeping your A/C or power steering ......it never bothered me.
IMO there are many positives in swaping the H into an EK car....it will be a great platform for many things...which way you go is your choice. I chose the swap because of the difficulty level and for what I wanted out of it in the end.
Just as a tip make sure you find someone truly capable of completing this swap-research there work and WIRING ( anyone can put a motor in your car---but not everyone can make it run RIGHT!!! ) if you do it your self I hope you have experience.....
HOPE THIS HELPS ALITTLE!!!
Old Sep 4, 2005 | 12:29 PM
dantastic's Avatar
dont look at the h22a faw sticky in the hybrid forum or anything: https://honda-tech.com/zerothread?id=650329
tonycecc
Apr 14, 2017 06:34 AM
mcaro
Dec 30, 2003 04:43 PM
Jago
Jul 22, 2003 01:08 PM
